Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2684158
08/03/19 08:08 PM
08/03/19 08:08 PM
it sure does point to it with that being the only change especially a back to back change which it sounds like this orange to chrome box swap was. I would hold off tho till the ballast arrives. Good things come to all who are patient (at least that's what I get told!), on a regular basis.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: Pacnorthcuda] #2685411
08/07/19 04:54 PM
08/07/19 04:54 PM
pa.
dan9 Offline
dan9  Offline
pa.
Also the connector at the base of the steering column. The one that comes from the ignition switch. My 70 just had the same problem. I took the blue and the red from the connector and soldered the wires together. When it dies do you loose power to everything? Mine did and itt was the red wire causing the problem
Re: 70 Challenger stalls abruptly. Advice needed. [Re: dan9] #2685462
08/07/19 07:06 PM
08/07/19 07:06 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
I hadn't thought of this. Where exactly is this? Is this that big connector with about 20 wires in it, or is this something else lower down, maybe towards the floor?
Thanks.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2685474
08/07/19 07:46 PM
08/07/19 07:46 PM
pa.
dan9 Offline
dan9  Offline
pa.
It is a flat plug with 6 or 8 wires near the floor. It comes from the ignition switch. The connector may be tucked up on top of the column.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: challenger70] #2685898
08/09/19 05:33 AM
08/09/19 05:33 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I bet orange box is quitting.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2686250
08/10/19 11:12 AM
08/10/19 11:12 AM
Chicago
PurpleBeeper Offline
Chicago
I think these guys nailed it immediately. I've had a similar problem when my ignition box was going bad. Sometimes you can even see they look a little gooey/melted on the back when they're going bad, but it's not always visible like that.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2686252
08/10/19 11:20 AM
08/10/19 11:20 AM
Chicago
Chicago
I"m skipping ahead here, but dan9 is onto something. If your car goes COMPLETELY dead, there's a blue wire under the hood (where the factory fusible link is located) that is the main power wire going into the bulkhead disconnect. And as I think dan9 is talking about, I've had issues with connections at the two plugs at the bottom of the steering column and the slightly larger plug (flat, 8 or so pins), has the main power going through it. Sometimes a teeny tiny screwdriver pushing the metal connecters together from both sides (slipping the tiny screwdriver inside the plastic plug hole, next to each wire, pushing forward on the metal connector itself) can fix issues where whole sections of electrical (eg ignition) just go dead all at once, but "usually" those bad connections don't fix themselves by sitting & cooling off for a few minutes.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: PurpleBeeper] #2686623
08/11/19 08:54 PM
08/11/19 08:54 PM
Los Angeles, CA
Los Angeles, CA
The back of my orange box was pretty soft. I could easily make indentations in it with my fingers when it was cold.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: SattyNoCar] #2686659
08/11/19 10:08 PM
08/11/19 10:08 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Originally Posted by Satilite73
Forgot to mention, make sure the ECU has a GOOD ground. Is there paint under those screws? On my cars where I can access the back, I'll use a nut and bolt rather than rely on self tapping screws. I'll also run a ground strap from the mount to the block too.
I agree
With him switching ECU s back and forth , could of created a cleaner ground by loosening and tightening bolts / screws
Ground wire to bolt right on ECU , even if temporary would bee a good solution / test - Would eliminate any grounding issues through that bracket itself
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2686662
08/11/19 10:12 PM
08/11/19 10:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Originally Posted by JF_Moparts
Oh, only other thing I can add is that when I had the car running I starting wiggling wires to see if any would cause the motor to stall. None caused a stall, but when I wiggled the passenger-side connector on the ballast resistor, it sparked. Not sure if that's normal!
Remove the resistor and see if the backside wire is exposed - Some are not
You can usually see where they are broken if exposed
Siberian Huskies
Re: 70 Challenger stalls abruptly. Advice needed. [Re: bee1971] #2686670
08/11/19 10:43 PM
08/11/19 10:43 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Last one I had do that the guy painted up the coil all pretty, new decal on it... it was a ford coil. Car would run quit, cool down a few minutes, then restart. Hot days were the worst, new mopar coil fixed it, orange box is still on it.
Re: 70 Challenger stalls abruptly. Advice needed. [Re: 4406bbl] #2687253
08/13/19 01:37 PM
08/13/19 01:37 PM
Los Angeles, CA
Los Angeles, CA
Well, I replaced the orange box and so far, so good. I've driven the car about 40 miles with no issues!
Re: 70 Challenger stalls abruptly. Advice needed. [Re: JF_Moparts] #2687718
08/14/19 01:55 PM
08/14/19 01:55 PM
pa.
dan9 Offline
dan9  Offline
pa.
Awesome!
