1975 Mopar A body Rear End/axle length/perch distance #2685129
08/06/19 08:56 PM
08/06/19 08:56 PM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
I found a tech archive that only covers up to 1972 A bodies rear end width's and axle lengths.
http://www.moparts.org/Tech/Archive/axle/16.html
However, I am wanting to know the oem length of a mopar rear end in a '75 A body.
Reason being is my car has a ford 9" stuck under it that has some issues that has some work needing to be done.
While it's out wanting to consider shortening it to correct length and relocate perches after shortening.
Spec's appreciated.
Thx in Adv. beer
Re: 1975 Mopar A body Rear End/axle length/perch distance [Re: moparz] #2685153
08/06/19 10:10 PM
08/06/19 10:10 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
sure it isn't a Mopar 8-3/4? They look very similar to a Ford 9".... same style rearend, welded rear cover, diff comes out the front of the housing.
Re: 1975 Mopar A body Rear End/axle length/perch distance [Re: volaredon] #2685274
08/07/19 10:25 AM
08/07/19 10:25 AM
scratchnfotraction Offline
spring perch is 43" centers
IIRC, brakes will determine actual width of A-body
stock 1 3/4 wide rear brakes axles has smaller brake offset than later A-body with larger brake offset.
large brakes will make the A-body 8 3/4 1/2" wider = 1/4" each side.
I used a set of moser large brake A-body axles with a set of 5on 4.5 wbp 11x2.5 brakes in my 68 Dart.
75 A-body has a open wheel well and a B-body 8 3/4 will work in a pinch with correct wheel backset to center tire/wheel in tub.
FYI one of those axle charts is wrong info.
I have the correct 1 3/4 brake offset axle measurement and the large brake offset axle measurement in my notes I will check.
A-body use a 29' axle so a B-body with 30" axle is best swap IIRC
94 jeep xj 8 1/4 is a close fit for a-body or the ferd exploder 8.8
Re: 1975 Mopar A body Rear End/axle length/perch distance [Re: volaredon] #2685320
08/07/19 12:12 PM
08/07/19 12:12 PM
yes 43" C to C for the perches. what issue are you haveing with it?
Re: 1975 Mopar A body Rear End/axle length/perch distance [Re: scratchnfotraction] #2686391
08/11/19 01:07 AM
08/11/19 01:07 AM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Thanks!
Re: 1975 Mopar A body Rear End/axle length/perch distance [Re: RapidRobert] #2686392
08/11/19 01:08 AM
08/11/19 01:08 AM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Just needed approx total width. Found what I need. Thanks for asking.
Cheers,
