I'm installing a 70 Cuda gas tank in a 72 Cuda. The tubes on the tank are on the pass side, while the car itself has the vapor vent canister dead center. Should I move the canister to the pass side and use the existing lines, or should I go with the vent TUBE that mounts in the truck pass side wheel well? I'm not going with the charcoal canister/1972 setup. Just want gas to flow and vent.
Grandma always said I had "hands of gold"!
