Rear Speaker Option 69 B-Body #2684299
08/04/19 12:41 PM
08/04/19 12:41 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Does anyone have an original 69 single rear speaker option?
Could you post some pictures of the speaker and chrome knob location.
I will also need the deminisions of the speaker.
The parts book shows the rear fader switch and wiring to be #2947394.
I will need both the speaker and the fader.
The speaker is the hard one, since other fader switches for 68 and 70 will work, just not the right part #.
The rear package tray on a 69 Bee has holes for 6x9's, but also has a hole for a 5x7 on the driver side next to the 6x9.
Thanks for your help on this!
Re: Rear Speaker Option 69 B-Body [Re: 6pkRB] #2684483
08/04/19 10:47 PM
08/04/19 10:47 PM
cbusters Offline
cbusters  Offline
I have a rear speaker, harness and the plate for the Rally dash that mounts next to the radio.
Re: Rear Speaker Option 69 B-Body [Re: cbusters] #2684624
08/05/19 10:56 AM
08/05/19 10:56 AM
Alabama
BigMoneyLewis Offline
Alabama
The rear speaker goes on the drivers side. The passenger side hole is for a rear defrost motor to mount .
Greg
gregward@mchsi.com phone 256-852-0955
Re: Rear Speaker Option 69 B-Body [Re: BigMoneyLewis] #2684780
08/05/19 08:09 PM
08/05/19 08:09 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Thanks Greg for the info.
PM sent to cbusters.
Re: Rear Speaker Option 69 B-Body [Re: 6pkRB] #2685006
08/06/19 03:07 PM
08/06/19 03:07 PM
cbusters Offline
cbusters  Offline
Re: Rear Speaker Option 69 B-Body [Re: 6pkRB] #2685010
08/06/19 03:30 PM
08/06/19 03:30 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
old photos on my '69 RR driver's side and dash speaker control
Re: Rear Speaker Option 69 B-Body [Re: A12] #2685035
08/06/19 05:01 PM
08/06/19 05:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That fader switch location is different...my '68 RR has it in the switch panel.
That looks like it's on the bottom of the dash.
Maybe that was a dealership or subsequent add-on?
Re: Rear Speaker Option 69 B-Body [Re: topside] #2685065
08/06/19 05:53 PM
08/06/19 05:53 PM
cbusters Offline
cbusters  Offline
68 and 69 are different and Rally vs. Standard gauges are different. I have samples of each that I pulled off of cars back in the 70's.
68 Belvedere in switch panel
69 Belvedere under dash
The one in the picture is for a Rally year unknown. Radio Bezel is 2889036 and Switch Bezel is 2864223-2 (not in the 69 parts book)
I have never seen one in a car, this is the only one I have ever seen.
Re: Rear Speaker Option 69 B-Body [Re: BigMoneyLewis] #2685077
08/06/19 06:31 PM
08/06/19 06:31 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Charger had the knob on the gauge cluster in '68, and under the ignition switch in '69. Is it in different locations on other models?
Re: Rear Speaker Option 69 B-Body [Re: 375inStroke] #2685133
08/06/19 09:10 PM
08/06/19 09:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
My 68 coro r/t with non ralley 150 speedo in same spot on dash, where I believe they also put conv't top switches on conv'ts.,
Re: Rear Speaker Option 69 B-Body [Re: buildanother] #2685151
08/06/19 09:59 PM
08/06/19 09:59 PM
cbusters Offline
cbusters  Offline
Do you mean on the switch panel?
Re: Rear Speaker Option 69 B-Body [Re: cbusters] #2685172
08/06/19 11:13 PM
08/06/19 11:13 PM
chicagoland,usa
chicagoland,usa
Yes, that black area to right of steering column.
Re: Rear Speaker Option 69 B-Body [Re: 6pkRB] #2685531
08/07/19 10:26 PM
08/07/19 10:26 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
please excuse the mess wink
5" X 7" with what appears to be 2589689 and DELUXE
The speaker control knob is to the right of the ignition key and very close to the left of the ashtray opening, on the bottom metal portion of the dash below the dash pad. The toggle switch to the left of the speaker control knob I'm pretty sure was installed by the second owner, I'm the third owner.
Mike
Re: Rear Speaker Option 69 B-Body [Re: A12] #2685570
08/08/19 12:09 AM
08/08/19 12:09 AM
cbusters Offline
cbusters  Offline
Mike
Interesting that trim screws are used on the speaker.
