68 GTS Parts - Help with vendor selection
#2684870
08/06/19 07:58 AM
08/06/19 07:58 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I need a short list of parts to get my GTS 100% reliable for stress free driving. Can any of you folks steer me in the right direction for quality resto parts?
My list:
Battery Cables Glove Box Liner Upper dash pad (68 only?) Window crank handles (rear) Defroster vents
Other than that I will be hitting up the fall sale for everything to do the interior. I am really looking forward to getting this thing sanitized on the inside!
Re: 68 GTS Parts - Help with vendor selection
[Re: Jeremiah]
#2684900
08/06/19 09:48 AM
08/06/19 09:48 AM
Posts: 43,594 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Dante's https://dantesparts.com/ABC Moparts is just starting to repop the 68 dash pad but Classic Industries says they have one now, but I haven't seen them personally.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2684955
08/06/19 12:39 PM
08/06/19 12:39 PM
Jeremiah
Rogue River, OR
Yep Dante is my first call. I was more referring to buy this brand battery cable because of xxxxx reason.
Thanks Jim! I figured we would be talking Darts with our new acquisition.
[Re: Jeremiah]
#2685046
08/06/19 05:19 PM
08/06/19 05:19 PM
Jeremiah
Rogue River, OR
Should this car have a plastic radiator shroud?
Also, I would like to get some type of interlocking motor mount for the driver side. I assume you have a change of breaking the exhaust manifold if the engine moved more than an inch or so. It looks like the standard motor mount with a-body specific brackets?
I also will need to replace the battery tray. Goodmark, Sherman, AMD or find an original?
Thanks again for any insight!
[Re: Jeremiah]
#2685069
08/06/19 06:23 PM
08/06/19 06:23 PM
Posts: 1,073 oregon
greendart408
oregon
Thanks again for any insight! Be careful on the re pop stuff you get, I just did a similar original patina 69, 340,4spd f8 dart like you are doing, most all I bought was complete scrap. All junk compared to the original stuff, the repop shroud is total garbage. Got it from classic, hopefully they are not all the same.....I'm super picky tho so? On a side note, it's the most epic car and fun ever, you will love it, I daily drive mine except in the rain and have put 9,500 miles of gear jamming fun on it in 1 yr.
[Re: greendart408]
#2685088
08/06/19 06:57 PM
08/06/19 06:57 PM
Jeremiah
Rogue River, OR
Okay I will try to find an original battery tray. Luckily the most complicated part I need is the upper dash pad. If needed I can have the original recovered here in town. Thank you for the heads up on the shroud too. I looked at all of the trim parts and lenses very skeptically also.
Break out some pictures of that car!
[Re: greendart408]
#2685389
08/07/19 04:11 PM
08/07/19 04:11 PM
Jeremiah
Rogue River, OR
I don’t want to ruin your post with my junk but since you asked. This thread is about Darts not me let it be seen! What a cool car. I like the tail strip with the dark green. We need to do a photo shoot with the two of them!
[Re: Jeremiah]
#2685886
08/09/19 03:57 AM
08/09/19 03:57 AM
Jeremiah
Rogue River, OR
Okay, exhaust system time!
I have Accurate and TTI in my sights. My gut feeling is to go 2.5" H-pipe from TTI as it's a driver. The price is not that far off with shipping considered as Accurate is semi local.
What would you guys do? I don't plan on selling the car this one will be in my auction lol. I do plan on keeping it day 2 stock (ish) because that is how it spent it's life. An h-pipe would be cool : D
[Re: Jeremiah]
#2687341
08/13/19 04:34 PM
08/13/19 04:34 PM
Rhinodart
Rhinotruck
Rhinotruck
Just you're run of the mill big block A-Body! Bright blue, console 4-speed, buckets, stripes, tires, and so forth. I will give a detailed decode shortly...
A-Body's RULE!
[Re: Rhinodart]
#2687355
08/13/19 05:02 PM
08/13/19 05:02 PM
Rhinodart
Rhinotruck
Rhinotruck
LS23=Dart Special Hardtop (GTS) 62=383 3=4-speed 39=E70x14 white wall tires 922=September 22, 1967 approximate build date 114671=S0# 2 5= Drip rail molding 3 0= Belt line molding (above door below window) 7 8=Wheel lip moldings AX=3.23 sure grip 8-3/4 QQ1=Bright Blue metallic U U=Light blue upper door frame paint S 9= Delete stripe D 9=Front disc brakes R 1=AM radio 2 watt T 7=Tachometer mounted on console X 2=Tinted windshield only a 6=Bucket seats b 4=console h 7=Fender mounted turn signals m 6= Outside left hand remote mirror
A-Body's RULE!
