Powermaster Rant. #2684801
08/05/19 09:32 PM
08/05/19 09:32 PM
MN
JERICOGTX Offline OP
MN
A couple years ago, I bought a Powermaster starter for my Road Runner. Got it installed, and tried to turn the engine over, and the starter gear was rubbing the flywheel ring gear. No problem... they send a shim with the starter. Pull the starter, install the shim, reinstall the starter.. the gear is now hung up on the flywheel ring gear... Pull the starter back out, remove the billet adapter to fit a Mopar, and install just that, with the bendix. The mounting holes are in the wrong location, just a touch, and simple enough? Open up the holes a little, test fit it, and it's working smoothly. Reinstall the adapter/bendix, install the starter, and hit the switch. Piece of junk sounds like a 6V starter from a Farmall M... I'm DONE with this POS. I just happened to pick up a new Denso for my 69, and it will be here tomorrow. Guess I know where it's going now.
69 GTX 68 Road Runner
Re: Powermaster Rant. [Re: JERICOGTX] #2684802
08/05/19 09:41 PM
08/05/19 09:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You will see the difference between "made in China" to "made in Japan" or even Denso America made in Detroit . The Powermaster products I have seen look like the same Chinese junk you find in a box from Autozone with a pretty paint job and a sticker. You will pay more for a genuine Denso starter but it will last forever twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Powermaster Rant. [Re: fourgearsavoy] #2684805
08/05/19 09:57 PM
08/05/19 09:57 PM
MN
MN
This wasn't the basic starter. It is the high end race starter Made in the USA. One reason I bought it.
Re: Powermaster Rant. [Re: JERICOGTX] #2684850
08/06/19 03:25 AM
08/06/19 03:25 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is super annoying. Especially doing stuff five times on a car with fresh paint.
I am not a power master fan. CVR and TuffStuff for this guy.
Re: Powermaster Rant. [Re: Jeremiah] #2684890
08/06/19 09:26 AM
08/06/19 09:26 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That sucks.
Their prices have always seemed out of line for what you actually get, and how little support is offered after the sale.
Rich H.
Esse Quam Videri
Re: Powermaster Rant. [Re: JERICOGTX] #2685083
08/06/19 06:47 PM
08/06/19 06:47 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Their quality must have gone down in the last few years. I used a Powermaster XS torque starter on mine and never had any problems with it for over 10 years. I'm surprised they wouldn't swap it out for you.
Re: Powermaster Rant. [Re: ZIPPY] #2685084
08/06/19 06:50 PM
08/06/19 06:50 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
You have the same starter as me right? Mine work awesome. If you are sure it is the starter, then it's defective and should get sent back. Just because i's been a couple years, shouldn't matter.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Powermaster Rant. [Re: Hemi_Joel] #2685091
08/06/19 07:07 PM
08/06/19 07:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Every time I read these posts it gives me a warm feeling all over knowing that my thriftiness pays off with me sticking to my budget 70.00 starters. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Powermaster Rant. [Re: Hemi_Joel] #2685115
08/06/19 08:27 PM
08/06/19 08:27 PM
MN
MN
Exact same starter as your Red car. The box is long gone, so I doubt I can send it back.
Re: Powermaster Rant. [Re: JERICOGTX] #2685131
08/06/19 09:09 PM
08/06/19 09:09 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep. I got one too. Lasted 2 months. Contacts are burned up in mine. Garbage.
Re: Powermaster Rant. [Re: JERICOGTX] #2685161
08/06/19 10:30 PM
08/06/19 10:30 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I would think the period correct starter for your ride would be of the “RAWR RAWR RAWR ZIIINNNGGG” gear reduction type..... laugh2
I would bet that whatever field/tree belt the Mirada is in now it probably still has the starter that I warranted on my 95 Ram.... and would still work.
Duster has another starter I scavenged at work.... “clicks won’t start”. They got a starter, I threw a set of contacts in the old one, just like the one I have on the shelf.
