'69 Roadrunner speedo WAY off #2684493
08/04/19 11:07 PM
08/04/19 11:07 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I just got a '69 Roadrunner and the speedo bounces quite a bit, but the worse part is that it reads about double your actual speed. Drive down the street at about 35-40 miles per hour and it will bounce between 65 - 80.
I'm sure the bouncing could be the cable being bound up, dry or has a bad end but I don't understand how it can read double actual speed. I don't know what speedo gear it has in but it can't be that, no gear will make it off that much. Tires are 215/70-15's.
I assume it's the speedometer head but I was hoping that I didn't have to replace it.
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2684502
08/04/19 11:31 PM
08/04/19 11:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lube the cable and try it again. A sticking cable can do what you describe. Think about the cable sticking and then popping loose. Remember is coiled pieces of wire.
Re: '69 Roadrunner speedo WAY off [Re: stumpy] #2684658
08/05/19 12:16 PM
08/05/19 12:16 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks. I'll start by giving that a try.
Re: '69 Roadrunner speedo WAY off [Re: stumpy] #2684765
08/05/19 05:58 PM
08/05/19 05:58 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Besides lubing your speedo cable, you also need a different speedo gear. If you know your rear end gear ratio and your tire diameter, you can select the right speedometer gear. It’s located where the speedo cable screws to the transmission. Check the tech archive under automatic transmission and you will find which gear you need. Sounds like your transmission is from a car with 2.94 gear and you have 3.55 gears. Which would create the situation you are describing.
Re: '69 Roadrunner speedo WAY off [Re: rapom] #2684837
08/06/19 12:15 AM
08/06/19 12:15 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I understand the speedo gear/tire size/rear end gear/etc but I do not believe that you can have a combo that would put you 100% off (my speedo shows ~double actual speed).
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2684843
08/06/19 12:57 AM
08/06/19 12:57 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It wouldn't. At 2500rpm there is only 20mph difference in those gears. Not even close to double. What happens when a speedo cable sticks is that it acts like a spring. It winds up and then springs loose making the speedo jump.
Re: '69 Roadrunner speedo WAY off [Re: stumpy] #2719791
11/27/19 04:00 PM
11/27/19 04:00 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I've removed the speedo cable and the ends look fine. I lubed the cable and there is no difference. In fact, at times the speedo will show 10-20 mph when the car is not moving. I guess I need to tear apart the whole darn dash to get the speedo out so I can take a look. I'm guessing some kind of return spring or the magnets...
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2719809
11/27/19 05:12 PM
11/27/19 05:12 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That is the last thing to do!
Replace speedo cable first .
A speedometer can read as high as your saying if the transmission has let's say a gear for a passenger car like a 318 Satellite with a 2.45 rearend ratio and you actually have 4.10-5.38's. Seen it been there. Mark the tire and mark the driveshaft and get an idea of what gear set is installed by counting the # of turns the driveshaft spins to one turn of the tire.
Then pull the speedo gear from trans and put in correct one.
If all that checks out maybe you have a bad speedo head.
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2719811
11/27/19 05:19 PM
11/27/19 05:19 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd consider replacing the cable - RockAuto doesn't have a B body list but the do show an E body listing - around $10
https://www.rockauto.com/en/catalog/plymouth,1970,cuda,7.2l+440cid+v8,1231759,interior,speedometer+cable,1440
I'd pull the cluster, remove the speedo and lube the pivot points for the needle on the speedo, any gears, and the flywheel assembly, with a paint brush very lightly dipped in wd 40. This is almost like jewelers work, lubing the insides of a watch. And I'd make sure the speedo cable interface on the back of the speedo isn't gummed up with 50 year old grease, or dry as a bone. It's real easy to ruin the face of a speedo with just the natural oils on your skin and fingers, never mind a lubricant, so judicious work is called for. I use a clean artists brush to dust off the face of gauges, so as not to smudge them. You can sort of bench test it by connecting the cable to a drill.
Re: '69 Roadrunner speedo WAY off [Re: Sixpak] #2719814
11/27/19 05:22 PM
11/27/19 05:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
When you removed the cable to clean and lube it did it spin easily or did it hang up at all?
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2719844
11/27/19 07:27 PM
11/27/19 07:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
My 75 Dart does the same thing even after putting a new cable in it. I think it is the speedometer that might be the problem. Does the odometer work right? If you go down the road and watch it and the mile markers, is it close to right, or not? The odometer is gears and the speedo works off of magnets.
Re: '69 Roadrunner speedo WAY off [Re: 71birdJ68] #2719917
11/28/19 12:31 AM
11/28/19 12:31 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Yes, I forgot to mention that. The odometer works fine and is accurate to distance traveled, it does not match the speedometer. I agree with you, it's the speedo itself.
It's not the cable or the gear in the transmission.
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2719919
11/28/19 12:41 AM
11/28/19 12:41 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Might just be dust and other particles that are getting between the rotating parts inside the speedo causing the problem. Realize it is a lot of work just to take it out and see, but you may be able to clean it out and then run it down the road with the speedo hooked up but not installed in the dash just for a tryout.
Re: '69 Roadrunner speedo WAY off [Re: John Brown] #2720006
11/28/19 11:22 AM
11/28/19 11:22 AM
moparx Offline
moparx  Offline
you could hook a cable up to the head while it's on the bench and use a drill to spin it in reverse [i think] to see if the symptom persists before putting it back in the car.
beer
Re: '69 Roadrunner speedo WAY off [Re: VITC_GTX] #2720044
11/28/19 01:00 PM
11/28/19 01:00 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
With this information them yes I agree it's a speedo problem.
Ron
