Re: Timing gear marks
[Re: 1BAD68]
#2685795
08/08/19 07:11 PM
08/08/19 07:11 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I would check the cam timing with the degree wheel, and adjust it as necessary to have it installed where I wanted it.
Which is the same thing I would have done with the other timing set.
Without checking it, you have no idea where it is.
[Re: 1BAD68]
#2685872
08/08/19 11:40 PM
08/08/19 11:40 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2685893
08/09/19 04:54 AM
08/09/19 04:54 AM
RapidRobert
With the multiple keyways get it to 106 or as close to that as you can & do check piston to valve clearance. As said a lesser # is advancing it & moves the powerband RPM range lower & retarding it (a higher #) raises it. Start with 106 & go from there.
