Magnum 360 380hp manifold
#2684067
08/03/19 02:40 PM
08/03/19 02:40 PM
Posts: 1,271 eastern long island,NY
JeepJimmy
Currently have the mopar magnum 360. 300hp crate in my 70 Duster. I have had the 380hp cam on the shelf. I would like to upgrade to this cam. Should i go to the single plane intake? That looks inpossible to find??? Or would my dual plane be ok? Not many options out there?? Also isthere any other differences between the two crate motor builds. Thanks!!
70 duster 360magnum, 1975 jeep j-10.
Re: Magnum 360 380hp manifold
[Re: JeepJimmy]
#2684169
08/03/19 09:04 PM
08/03/19 09:04 PM
RapidRobert
I seen a pic of where a guy used a LA intake on a magnum by redrilling the bolt holes vertical & a bit of spot facing then a spacer that the bolt first goes thru,square on one end & angle on the other end to match the intake surface angle. But I would first stick with the dual plane & definitely confirm that that cam is a good choice (I ain't sayin that it ain't cuz I ain't a cam guy). But here's a BTT for ya
[Re: RapidRobert]
#2684170
08/03/19 09:15 PM
08/03/19 09:15 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have a 380hp 5.9 with a Mopar M1 dual plane intake. Works great for a street car,
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
