Page 6 of 6 1 2 3 4 5 6
Re: picked up a 80688 holley 1050 to try [Re: Thumperdart] #2503266
06/01/18 05:25 PM
06/01/18 05:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted By Thumperdart
Emulsion #i and #4 at .026 in addiction to the other stuff...........
Are you saying you want me to drill #4 emulsion blank hole to .026?
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2503270
06/01/18 05:35 PM
06/01/18 05:35 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
do your metering blocks have threaded emulsion holes?
if so, put blanks in all spots except #1 and #4. you can also do #1 and #3 though...
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2503277
06/01/18 05:58 PM
06/01/18 05:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What he sad............if they are threaded, plug 2, 3, and 5 if not drill n tap em for 6-32 set screws........... beer
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2503310
06/01/18 07:39 PM
06/01/18 07:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I plugged mine with a piece of lead shot.
Re: picked up a 80688 holley 1050 to try [Re: justinp61] #2503331
06/01/18 09:00 PM
06/01/18 09:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
For sure easier than drilling n tappin just not as clean plus a [censored] if you want to play w/different emulsion sizes and locations........... beer
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2503491
06/02/18 09:33 AM
06/02/18 09:33 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want to get going down the road at this point without fouling plugs is all.No mistake I will do more tuning on the metering plate and appreciate your help.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2503575
06/02/18 01:44 PM
06/02/18 01:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you go all out on this thing and get it bad ass, not only will you learn how to tune each circuit but you will have a damn near EFI running car and plugs and oil will go many more miles than before GUARANTEED.................... beer
Re: picked up a 80688 holley 1050 to try [Re: Thumperdart] #2503637
06/02/18 05:26 PM
06/02/18 05:26 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: picked up a 80688 holley 1050 to try [Re: justinp61] #2503646
06/02/18 05:52 PM
06/02/18 05:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Just to see what it would take I used a small fishing line crimp on sinker,pounded it flat to .090 and cut into slivers with a wood chisel to fit but I didn't try to pound it in.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2507972
06/13/18 03:34 PM
06/13/18 03:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got to go around the block and things are looking good with the carb adjustments given so Thank you thumperdart!I have more to do but I can drive it to do so.The a/f was in the 13 to 14.5 but I had a 84 in the sec jet and will put in a 86 and see.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2508038
06/13/18 05:51 PM
06/13/18 05:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You are welcome and glad I could help ya out............. thumbs
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2530362
08/02/18 09:23 AM
08/02/18 09:23 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I now have 88 pri 91 sec jetting and I am getting ready to put in the power valve and adjust the channel restriction.The car launches ok with a slight spit out the carb after the pump shot burns off and the engine temp was only 130.I will test the pv effect with a test launch and a hotter engine and check the plugs and go for a longer drive above 3k rpm to see the o2.
ps:The sec open at 1/4 throttle so it comes in early.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2683808
08/02/19 07:55 PM
08/02/19 07:55 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Bump for my info I need to read.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2684247
08/04/19 09:36 AM
08/04/19 09:36 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My question at this point is with t-slot jetting.I put in a .047 pri/sec and now I am fouling plugs.What jet would you go to to get an a/f from 11/1 to the 13/1 range?I was thinking of going to a .040 on all 4 with no pv and sq jetting.I took the air filter off and started having fuel fouled plugs.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2684380
08/04/19 05:50 PM
08/04/19 05:50 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I would think under 0.050 t slot would be getting on the too small .
IIRC my 1050 is 0.059 or a hair smaller. This is where I have it now on my 505 , may have been a hair bigger on my 440 . 505 pulls harder on carb . On the 440 it was #82F #98R , on the 505 I only needed to go #100 rear . It has a PV
Have you altered the IFR jetting , I took mine from 0.045 to 0.044 and lowered it . Was noticeable . I also increased to PVCR from 0.070 - 0.073
I do think I need to increase the T slot back a hair for street driving , though it is winter here and I will see how it goes as it warms up .
I am running the 1050SP sportsman aluminium 4500 .
Good luck . Knowing it will never be perfect I am looking for close , 90%
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: picked up a 80688 holley 1050 to try [Re: tex013] #2684444
08/04/19 08:37 PM
08/04/19 08:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the tips.I have the carb off and making some set screw jets [brass]If I was giving advice on this I would say check the pv gasket.I put on an 850 while I look hard at things,clean,think more of what I am doing.I work slow.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2684499
08/04/19 11:22 PM
08/04/19 11:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
A good O2 system can be a great help dialing in carbs. up
Especially pump gas big CFM carbs. like Dominator and 950+ CFM 4150 carbs. up scope
With enough work you can make them motors real tire spinners devil boogie grin
Re: picked up a 80688 holley 1050 to try [Re: Cab_Burge] #2684579
08/05/19 09:29 AM
08/05/19 09:29 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have the o2 on the dash but with sun glare is hard to see sometimes.The o2 helps a lot.
ps here you can see the o2 is hard to see. Test launch a/f
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2684639
08/05/19 11:33 AM
08/05/19 11:33 AM
Will your set up store data?
Mime does, Innovate LM1 with the RPM and LC1 add on for dual readings instead of one side only up
Push record and read it later on the desk top or have some one watch it in real time with a lap top in the car up
Re: picked up a 80688 holley 1050 to try [Re: Cab_Burge] #2684652
08/05/19 11:57 AM
08/05/19 11:57 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am trying to use the video to record all info but I think it can plug into a laptop.I don't remember to turn on the camera half the time.lol
