TCI Flexplate Sheild BB Mopar Ebody #2683772
08/02/19 05:41 PM
08/02/19 05:41 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Old question...new racer.
Will any of these flexplate shields fit my stock Ebody transmission tunnel or do I need to cut the tunnel out?
I'm running a 727 Torqueflight
Wish there was a SFI case
Re: TCI Flexplate Sheild BB Mopar Ebody [Re: Chip] #2683858
08/02/19 10:01 PM
08/02/19 10:01 PM
I bought and used a blanket on my last car I built, way better than the shields IMO up work
Re: TCI Flexplate Sheild BB Mopar Ebody [Re: Cab_Burge] #2683923
08/03/19 06:12 AM
08/03/19 06:12 AM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Thanks for the reply.
So you used a blanket that covered the bellhousing also?
Anybody used a J.W. SFI Bellhousing for their TF727?
This one here...
https://racewithjw.com/product/ultra-bell-big-block-chrysler-to-tf727-or-a518/
Re: TCI Flexplate Sheild BB Mopar Ebody [Re: Chip] #2683930
08/03/19 07:22 AM
08/03/19 07:22 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I managed with a 69 B body with no mods to the trans tunnel but I did mod the shield and never got the boot at the track for it.I bent at a 90 where the bolt tabs are on the shield[1"+] in and when in the car it buts against the firewall.I will get so pics if you like.
Re: TCI Flexplate Sheild BB Mopar Ebody [Re: Chip] #2683932
08/03/19 07:23 AM
08/03/19 07:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know what your ET is but you might look at the CSR shield, it takes care of the flywheel and trans. As far as I know there is no blankets that cover the flywheel area. If you don't go the CSR shield route the JW Bell and trans blanket combo is probably the safest and easiest.
I had to do some pretty extensive massage work to get a CSR shield on the 904 on my a body. I didn't have to cut anything out but I had to use an air hammer to make the whole right side of the tunnel larger. I would imagine an E body to be easier but I have no idea.
68 Barracuda Formula S 340
Re: TCI Flexplate Sheild BB Mopar Ebody [Re: Chip] #2684005
08/03/19 11:12 AM
08/03/19 11:12 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
CSR shield here, 727 E Body. Had to flatten the bulkhead / floor pan seam for it to fit
HTH's up
