what size bolts/screws
#2682861
07/30/19 09:03 PM
07/30/19 09:03 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
46RE transmission filter bolts/screws were missing when I bought my 03 Durango 5.9 last week. So was the pan gasket (but that's a whole 'nother story ) They are not #12- 24 - too small and not 1/4" like the valve body mounting bolts too big. Thought metric but 5mm .8 is too small. thought i tried a 6mm .8 and found it too big. Thoughts? Thanks, Scott
Re: what size bolts/screws
[Re: Scott Carl]
#2683389
08/01/19 10:38 AM
08/01/19 10:38 AM
Posts: 19,485 north of coder
moparx
try a 6.0-1 screw. can't help with the length, and i think mopar is too cheap to specify a special thread pitch. take out one of the VB screws by the filter area and take it with you when you go to wherever you are going to try to find screws. get the length a little longer than the one you took out. by how much, i can't help.
