what size bolts/screws #2682861
07/30/19 09:03 PM
07/30/19 09:03 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
46RE transmission filter bolts/screws were missing when I bought my 03 Durango 5.9 last week. So was the pan gasket (but that's a whole 'nother story rolleyes ) They are not #12- 24 - too small and not 1/4" like the valve body mounting bolts too big. Thought metric but 5mm .8 is too small. thought i tried a 6mm .8 and found it too big.
Thoughts?
Thanks,
Scott
Re: what size bolts/screws [Re: Scott Carl] #2682884
07/30/19 09:40 PM
07/30/19 09:40 PM
Order new ones from your local Dodge/Chrysler dealer scope
Re: what size bolts/screws [Re: Cab_Burge] #2683195
07/31/19 07:46 PM
07/31/19 07:46 PM
Omaha, Nebraska
Omaha, Nebraska
I would order them but they'll take 2 weeks!! and they're $5 ea for 80 cent bolts. Yeah, I'm that cheap! Is there such a thing as 5.5mm screws? Its the only thing that makes sense. Unless Mopar has their own specially designed thread size and pitch that only works in the transmission filter screw holes realcrazy
Re: what size bolts/screws [Re: Scott Carl] #2683277
07/31/19 11:04 PM
07/31/19 11:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look up mopar parts online and they should have a picture and description of the bolts, Including size.
Re: what size bolts/screws [Re: Scott Carl] #2683389
08/01/19 10:38 AM
08/01/19 10:38 AM
moparx Offline
moparx  Offline
try a 6.0-1 screw. can't help with the length, and i think mopar is too cheap to specify a special thread pitch.
take out one of the VB screws by the filter area and take it with you when you go to wherever you are going to try to find screws.
get the length a little longer than the one you took out. by how much, i can't help.
beer
Re: what size bolts/screws [Re: moparx] #2683629
08/02/19 10:38 AM
08/02/19 10:38 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Here's the page from the 2003 parts book. The screw is item #7. If you can't read it, the size is .19-24 X 2.5"
Re: what size bolts/screws [Re: moparx] #2683686
08/02/19 01:06 PM
08/02/19 01:06 PM
Omaha, Nebraska
Omaha, Nebraska
Thanks guys. Figured it out. I found a source online that had a good picture and it dawned on me that I was way over thinking it. Thought they screwed into the valve body. Forgot they go THROUGH body and into case. They are about 3" long and about a coarse #10 with a torx head. Turns out I had them all along in a bag of miscellaneous hardware the previous owner included on the deal. I was wondering what thos long skinny screws were. whistling Embarrassed but relieved rolleyes
Re: what size bolts/screws [Re: Scott Carl] #2683999
08/03/19 11:03 AM
08/03/19 11:03 AM
moparx Offline
moparx  Offline
pretty neat you found the bolts ! it's always the little things that seem to bite a guy.
twodoorpost, thanks for that VB parts drawing ! up i believe the .190-24 thread is a 10-24. those are common VB screw sizes, and after measuring a 727 VB screw, the od of the screw is .1898.
beer
