Re: SPEEDOMETER GEAR
[Re: JohnH]
#2682856
07/30/19 08:49 PM
07/30/19 08:49 PM
RapidRobert
I went by the MP chart once & it was dead on. But if the speedo for instance is 12 MPH slow at say 60 MPH (shows 48 MPH) you would need 20% (12 divided by 60) less teeth on the pinion than what is in there now to speed it up 20%. For example if it has a 30 in there now you'd wanna get a 24. Jack up the car as high as you can on the dr side to minimize fluid loss & as you know clock the pinion adapter on the side of the trans to match the tooth count of your new pinion.
[Re: JohnH]
#2683102
07/31/19 01:24 PM
07/31/19 01:24 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Actual math shows you need a 35.79 tooth pinion but I would check the odometer for accuracy first. If the odometer is correct and the speedo is off, the problem is in the speedo head.
[Re: lewtot184]
#2684512
08/05/19 12:23 AM
08/05/19 12:23 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
What is the gear in the transmission now and 12 mph off at what speed? As Kunkel mentioned the odometer is a better check because 12 off is not 12 off at 0 mph or still 12 off at a higher speed. If it was, the problem would be a bent needle.
[Re: Magnum]
#2685481
08/07/19 07:52 PM
08/07/19 07:52 PM
Posts: 549 WV
JohnH
WV
