Shimming your starter #2682742
07/30/19 03:50 PM
07/30/19 03:50 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I put the 5.7 in my dart sport and was getting a weird noise while priming the motor, sounded like the starter was getting hung up, that same noise.
the combo is
5.7L Hemi
904/ATI flex plate
Mopar Mini Starter
TTI long Tube headers
Nothing fancy, has anyone had to shim there starter?
Thank you
Kiddart
Re: Shimming your starter [Re: Kiddart] #2682835
07/30/19 07:57 PM
07/30/19 07:57 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yes I had to shim mine .150 with a Reid Glide and Mopar mini starter.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Shimming your starter [Re: Kiddart] #2683527
08/01/19 09:05 PM
08/01/19 09:05 PM
Australia
aus370 Offline
aus370  Offline
Australia
904 trans , had to shim my starter 3mm
Re: Shimming your starter [Re: aus370] #2684695
08/05/19 02:53 PM
08/05/19 02:53 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I think I may have to replace my starter. It looks like it is getting hunk up on the converter. there are a few shinny teeth in one area but when I looked at the starter it was far enough away from the teeth. at this point what's another $100 or so.
I don't really have to much money invested in this to date.
I will keep you all posted.
Thank you
Kiddart
