The color red #2682408
07/29/19 03:54 PM
07/29/19 03:54 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I can't seem to get myself to not turn on the dang thing ..
The old motor combo, etc ..with my Terminator switch, 3 rings on it .. typically, it was about .030 , often double 0.. not often red
Now, 1 ring left, I think it needs at least one to work right .. ,002-- to .010 red ..all the time ,can't seem to stop it , red 15 times out of 20
I have front tires down to 27Lbs .. Don't think any less will help , don't want to run tires much lower
About ready to switch to delay box
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: The color red [Re: bigdad] #2682418
07/29/19 04:14 PM
07/29/19 04:14 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
.. add a couple washers under the button I'm sure the extra weight would slow it down
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: The color red [Re: WHITEDART] #2682422
07/29/19 04:24 PM
07/29/19 04:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I watched good friend Michael Beard this year dialing in his foot brake car. He was doing great but wasn’t quite were he wanted to be on the tree so he went to a deeper rear gear to dial it in. I thought he was nuts but he is now on kill and winning almost every weekend. Like he said there’s more to it that shock adjustments and tire pressure.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The color red [Re: pittsburghracer] #2682425
07/29/19 04:33 PM
07/29/19 04:33 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Due to power band on motor, I did put 4.30's in it .. did not want to buzz it too hard .. going to switch to a taller rear tire , that might help too
I could try one heavy steel washer that might take a bit of spring away , good idea
Re: The color red [Re: bigdad] #2682451
07/29/19 05:22 PM
07/29/19 05:22 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yep, tire size(front and rear for different reasons) and gear ratio all affect reaction time. On the driver side alcohol, caffeine, and some drugs(prescription and shall we say nonprescription) can have an effect on reaction times.
Many years ago a friend was consistantly loosing in the first or second round. I told him to knock off the pot the day before and after weeks of denial he finally tried my suggestion and hello, all of a sudden we're going home after midnight.
How many older racers do you know who can't hit the tree anymore? Heart meds are notorious for this.
Re: The color red [Re: GomangoCuda] #2682455
07/29/19 05:28 PM
07/29/19 05:28 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Big Dad- I had the same problem a couple years back. Kept hitting a skinny red. (More of a pink, really...) I have taken a couple turns out of the torsion bars and gained enough to get back to green.
Re: The color red [Re: Greenwood] #2682506
07/29/19 08:01 PM
07/29/19 08:01 PM
Washington
skrews Offline
skrews  Offline
Washington
^^^ Yep. Increase the front end travel if possible.
Re: The color red [Re: skrews] #2682533
07/29/19 09:41 PM
07/29/19 09:41 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
My car is torsion bar delete
Re: The color red [Re: bigdad] #2682534
07/29/19 09:50 PM
07/29/19 09:50 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Just red light waiting to happen
Re: The color red [Re: bigdad] #2682541
07/29/19 10:03 PM
07/29/19 10:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You know a guy's had seat time when he's adjusting the mirror with the wheels in the air ! up laugh2
Re: The color red [Re: topside] #2682544
07/29/19 10:08 PM
07/29/19 10:08 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
My t-brake switch is mounted high
Re: The color red [Re: bigdad] #2682560
07/29/19 11:01 PM
07/29/19 11:01 PM
Try adding some air(.5 to maybe 2.0 Lbs.) to the rear tires to see if it will make the car 60 Ft. quicker instead of jerking the front end up so high scope twocents
If that doesn't help try slowing the front end travel down some, make it stiffer on the extension wrench
Re: The color red [Re: Cab_Burge] #2682566
07/29/19 11:26 PM
07/29/19 11:26 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I've moved air around on both rear and front ..
did make a small difference but I think I've done all I can there .. it goes 1.38 or so in the 60 most days when air isn't horrible
Re: The color red [Re: bigdad] #2682624
07/30/19 09:36 AM
07/30/19 09:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Play with the launch rpm. Try giving it a little more
Re: The color red [Re: bigdad] #2682646
07/30/19 10:15 AM
07/30/19 10:15 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Assuming you have coilovers can you lower the ride height?
Re: The color red [Re: 340Cuda] #2682751
07/30/19 04:21 PM
07/30/19 04:21 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Knock a few degrees of timing out of it, that worked for me. And if you have a digital box you can ramp it back in over time too. Keeps from hitting the tire too hard when the track starts to go away.
Re: The color red [Re: 340Cuda] #2682815
07/30/19 06:58 PM
07/30/19 06:58 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I can try that too .. think I'll just try it with no trans brake
Re: The color red [Re: bigdad] #2682885
07/30/19 09:40 PM
07/30/19 09:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
As crazy as it may sound try different fingers.. or applying more pressure to the button when pushing down
Re: The color red [Re: bigdad] #2682922
07/30/19 11:17 PM
07/30/19 11:17 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Can you maybe run a taller front tire?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
