Re: Need ideas-My 38- UPDATED PICS-whatyuthink?
[Re: RUMBLON]
#268217
03/30/09 05:34 PM
03/30/09 05:34 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
almost there/. NOW, tonights Martini will be to sit and look at the trunk and decide how to build an interior Cigar humidor and martini transporter and fab all that into the back to look COOL!!! DAVE
[Re: bohmer2]
#268218
03/30/09 05:53 PM
03/30/09 05:53 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
So, if I went with 17s out back, would 15s up front look wierd!
Dave,
I would think that 17's and 15's would look fine on that car. The key to me would be the ride height on the front end then you have to figure out how to get the rake or look you want the car to have. Some of this can be adjusted by how much sidewall you have on the tire (how much total height you have in the tire and wheel)
Its a real shame you dont have someone photoshopping this car build then you could get an idea what it would look like 15's front and back and 17's on the back.
I don't know for sure on his 38, but my 40 is really pushing it with cop wheels (15X8?). I forget the tire size, but it's to wide to drive. Unless you can find a narrow 17 wheel and tire, it's going to require cutting. Different size wheels can look okay, provided you have equal or bigger sidewall on the bigger wheels. They DO look funny with equal diameter.
[Re: RUMBLON]
#268220
03/30/09 06:43 PM
03/30/09 06:43 PM
RUMBLON
Cambridge Idaho
I think I will loose the ribbing, ir metal pieces that run through the dash, fix the drivers side to accept 5 gauges. The piece in the pic is for a console I am doing but you get the idea.
dave,
[Re: RUMBLON]
#268224
03/31/09 03:05 PM
03/31/09 03:05 PM
RUMBLON
Cambridge Idaho
OK, I have two sets of these---hidden hinges, I bought them several eyars ago for another project and never used them. Are they hard to install? Anyone have experience with them. It would allow me to shave the three exterior hinges off of the car and make these doors swing either way____ correct.
what ya think. This one box was opened years ago and I hope all the parts are there, but the second box is sealed.
[Re: RUMBLON]
#268226
03/31/09 03:14 PM
03/31/09 03:14 PM
RUMBLON
Cambridge Idaho
WHAT should I use for
trunk locks, latches, electric, ect???
door locks handles, shaved or leave original or more modern????
Electric window kit?
What new brake booster and pedal assembly? new or junk yard, what works if I go look in a yard. They are not prcy new, what to look for??
hood latches and hardware??? any suggestion? any luck with certain brands, items? or keep it stock and make them look pretty?
what seat companies or seats do you like that will fit, IE, STREET ROD SEAT COMPANIES OR MODERN SEATS FROM A YARD THAT CAN BE DONE???
What steering columns to consider and
Is Ron Francis a good company to consider getting my wiring from?
what sound deadener do you guys use? I see some self adhesive, what brands do you like.
[Re: RUMBLON]
#268232
03/31/09 07:08 PM
03/31/09 07:08 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Dave the car will probably go together and apart a few times before your done, that's just the way it works "YOU" have to deiced if you want to do the hidden hinges(do the extra work) and then you have to figure out if you want them to open regular or suicide. now when I go with suicide doors I like to make the window go down and reach inside to open the door, I dont like to have poppers on suicide doors because you could have a real mess if the door were activated while driving and I always make sure befor I put the car in gear that I have the doors locked. you can get a keyfob setup that will alloy you to put the window down and you can open the door only from the inside, that way you could always get out even if you had a dead battery. you also will need to have a way to get power to the battery(lugs like on a race car under the car someplace) so if you have a dead battery you could still get the car jumped and get the windows down. to get to the battery... I hope that was not confusing,I know what I was saying just not sure it reads right and If you were to move the headlights down and do the work to the side panels maybe you could cut out the stock area and replace it with the chrysler fire power or some louvers just a thought but then you will be making new side panels(more work) it all depends on what your final goal is. AIN'T THIS FUN!!!!!!! you can do whatever you want Ron...
[Re: bohmer2]
#268233
03/31/09 07:56 PM
03/31/09 07:56 PM
RodStRace
Chino Valley
Dave, so many questions!! Maybe that's why the yuppies haven't ventured over here! DISCLAIMER! This is all personal opinion, not THE RULES! Hinges: Look at the cars posted. The Red with Blue flames is the only one without. It's a lot of work, but does look nice. The guy doing the work or paying for it gets to choose. Headlights: The Orange one with flames (notice it's the same car, different flames?) has smaller headlights mounted lower. He also took out the hood bulge, and replaced it with louvers. Trunk lock: Electric is fine. The big 3 all had 'em. Just remember that if the battery is in the trunk, you want MANUAL! See other thoughts below. Door handles: Shave them if you are doing the hinges. I prefer more stock, but as a body guy and the other choices you have made, it would match your build. Electric, same as the trunk, you want to be able to access without power. Street Rodder has a few vendors that sell the solenoids and buttons. Electric windows: Lil John Buttera did a cool deal, he had a remote that rolled down the window, allowing him to reach in to open the door. No outside buttons for the doors (theft resistant). Again, gotta figure out what happens when there is a battery problem. Also, it stinks in the rain. Brake parts: Depends on if you want it up on the firewall (more lumps to smooth) or under the floor (where you need an access panel). Kits both ways, and junkyard stuff too. Best to get something that is easy to find and cheap. You don't want to use a 1971 only E body Hemi booster! The major rod and Mopar brake guys can size a system for you. I went with 4 wheel disc, vacuum booster and M/C underfloor. Hood latches/hardware: Stock will do or you can go crazy. Inside releases, Hinges that open all sorts of ways, etc. That can wait until you have gotten closer to paint. Seats: There are a few Rod seat vendors. Most are big bucks. To save a few bucks and get it on the road sooner, try junkyard seats. The seat must be selected to make sure you fit and are comfortable, and you have good visibility. Then you mount the steering column! Don't forget being able to lay your arm on the door if that's required! Steering columns: there are big buck billet columns or you can search for a stocker. If you have a few bucks, go for a tilt. After the early eighties, GM and Mopar used the same columns. Make sure you get the key! Also, if you want a floor shift, get a column without the shifter. Wiring will depend on all the other components, but it makes sense to check with the wiring companies to see what they offer normally and what costs more. Ron Francis has a column in Street Rodder each month. Good Info. Sound deadener: The name brand is dynamat. There are others all the way down to stuff you get at Home Depot. Other thoughts: It seems like you are heading toward a modern 90s and newer style rod. Flashy paint, modern drivetrain and suspension, body mods, A/C P/S, PDB, P/W, P/L. Great choice and will fit in well with Goodguys and other big meets. You may not be welcomed with open arms at more traditional meets. That's okay too. If you plan on showing or selling, the guys that buy this type of rod will KNOW and look for name brands. If you have XYZ brand seats, wiring, interior, insulation, wheels/tires, and other stuff, it will be more accepted. It will also cost more. It might even be a little easier to assemble, since these are known quantities that other builders are experienced with. However, there are a TON of little things that will require thought, discussion, modification and maybe even tossing out and starting fresh. That's what makes it your rod. I'd suggest trying to find a bunch of old street rodder magazines and any others you can find. Hit the swap meets or advertise locally (you don't want to ship!) and try to find the guy that's clearing out a bunch. It will give you a better idea which vendors have been around a while, how to do stuff, and how others have done things. You can look at a car you think is ugly, but there will be one little detail that makes you go HMMMM. Or it will have 3 things you will make sure you don't do on yours.
