Re: Overdrive Feedback
[Re: ProSport]
#2681919
07/27/19 11:08 PM
07/27/19 11:08 PM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Check the tires for roundness. We see more and more tires that are shaped like an egg. And they will balance to all zeros, but at certain speeds will shake a lot. I have a pair of MT DRs that are about as bad as I have seen. They are even worse than the ones they replaced. At 70MPH, they are down right uncomfortable.
Also check the axle flanges for true.
Master, again and still
[Re: ChrgrCuda]
#2681922
07/28/19 12:30 AM
07/28/19 12:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I love my 518 in my Rampage.. have a 416ci in it with 4:10 gears and 4000 stall.. I dont run a lock up just the OD so at 70mph going down the E-way I cruise at 2900 rpm.. without the OD I dont know what it would be cruising at
[Re: DaveRS23]
#2681939
07/28/19 06:39 AM
07/28/19 06:39 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Also check the axle flanges for true. There are balancing machines that will measure road force variance , find a shop that has one and let them measure your tires.
[Re: MR_P_BODY]
#2681961
07/28/19 09:33 AM
07/28/19 09:33 AM
Posts: 4,209 New York
polyspheric
New York
The formula to get this is 1 ÷ your OD ratio X current RPM. 1 ÷ .69 = 1.45 X 2,900 = 4,200 RPM
Boffin Emeritus
[Re: Guitar Jones]
#2681963
07/28/19 09:38 AM
07/28/19 09:38 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Also check the axle flanges for true. There are balancing machines that will measure road force variance , find a shop that has one and let them measure your tires. I have had tires 'road force balanced'. But when tires are not round, the only thing that will address it is 'shaving'. But it is expensive and often hard to come by. There is not a tire shaver within 100 miles of us.
