Machine Shops in N. County San Diego or S. OC #2681618
07/26/19 03:26 PM
07/26/19 03:26 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I'm looking for a recommendation on getting a pair of Edelbrock heads checked and prepped for service in either north San Diego County or south Orange County. Anyone ever use the machine shop at Paradise Motorsports in San Macros? Thanks!
Re: Machine Shops in N. County San Diego or S. OC [Re: 67Satty] #2681633
07/26/19 04:32 PM
07/26/19 04:32 PM
San Diego, USA
SoCalRacer Offline
SoCalRacer  Offline
San Diego, USA
I've only used Paradise to resurface a flywheel and they did a nice job. The machinist I worked with was knowledgeable and conscientious, which is what I look for the most. I'm assuming you just want to check valve guide clearance, valve springs & installed height, maybe flatness and the valve job? I'm sure they could handle what you need.
I had a set of Eddy heads milled to get some more compression ratio at a place in Mission Gorge area of San Diego called Wholesale Automotive Machine who did a balls-on-accurate job......I know because I measured everything before and after. Like most shops they have an old-timer who knows what you need, and a bunch of young guys who make me nervous.
If it ain't broke ... you're not pushing it hard enough.
Re: Machine Shops in N. County San Diego or S. OC [Re: SoCalRacer] #2681647
07/26/19 05:29 PM
07/26/19 05:29 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Gregg Luneack does heads for Stock and Super Stock Mopars
Real Men shift for themselves
Re: Machine Shops in N. County San Diego or S. OC [Re: 67Satty] #2681648
07/26/19 05:41 PM
07/26/19 05:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
IMM in Indio is a thought....
Re: Machine Shops in N. County San Diego or S. OC [Re: J_BODY] #2681851
07/27/19 04:48 PM
07/27/19 04:48 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I'll second that.
Re: Machine Shops in N. County San Diego or S. OC [Re: Skeptic] #2681880
07/27/19 07:23 PM
07/27/19 07:23 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
IMM would be my first choice but with my schedule the only way I'd be able to drive out there is if they are open on Saturdays.
Re: Machine Shops in N. County San Diego or S. OC [Re: 67Satty] #2681901
07/27/19 09:18 PM
07/27/19 09:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
call and ask...I believe they are there until noon....at least the one time i went to indio...
Tony
70 AARCuda Vitamin C
Re: Machine Shops in N. County San Diego or S. OC [Re: 67Satty] #2681914
07/27/19 10:35 PM
07/27/19 10:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Greg would be my choice, I've used him before on a NHRA 340 stocker motor with excellent results up scope
He has built and raced Mopars almost as long as me grin whistling
I'm not a machinist either, just a assembler wrench
Re: Machine Shops in N. County San Diego or S. OC [Re: 70AARcuda] #2681923
07/28/19 12:32 AM
07/28/19 12:32 AM
SoCal
Brian Hafliger Offline
SoCal
I can meet you down at the shop on most any Sat....
Brian Hafliger
Re: Machine Shops in N. County San Diego or S. OC [Re: Brian Hafliger] #2681974
07/28/19 10:04 AM
07/28/19 10:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ll pretend I didn’t read that..... I prefer a decent excuse to skip a day of work!
Re: Machine Shops in N. County San Diego or S. OC [Re: Brian Hafliger] #2682033
07/28/19 02:07 PM
07/28/19 02:07 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Thanks Brian
