Re: Machine Shops in N. County San Diego or S. OC
[Re: 67Satty]
#2681633
07/26/19 04:32 PM
07/26/19 04:32 PM
Posts: 51 San Diego, USA
SoCalRacer
San Diego, USA
I've only used Paradise to resurface a flywheel and they did a nice job. The machinist I worked with was knowledgeable and conscientious, which is what I look for the most. I'm assuming you just want to check valve guide clearance, valve springs & installed height, maybe flatness and the valve job? I'm sure they could handle what you need.
I had a set of Eddy heads milled to get some more compression ratio at a place in Mission Gorge area of San Diego called Wholesale Automotive Machine who did a balls-on-accurate job......I know because I measured everything before and after. Like most shops they have an old-timer who knows what you need, and a bunch of young guys who make me nervous.
If it ain't broke ... you're not pushing it hard enough.
[Re: SoCalRacer]
#2681647
07/26/19 05:29 PM
07/26/19 05:29 PM
Posts: 608 TN
1DGEMAN
TN
Gregg Luneack does heads for Stock and Super Stock Mopars
Real Men shift for themselves
[Re: 67Satty]
#2681901
07/27/19 09:18 PM
07/27/19 09:18 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
IMM would be my first choice but with my schedule the only way I'd be able to drive out there is if they are open on Saturdays. call and ask...I believe they are there until noon....at least the one time i went to indio...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2681923
07/28/19 12:32 AM
07/28/19 12:32 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
IMM would be my first choice but with my schedule the only way I'd be able to drive out there is if they are open on Saturdays. call and ask...I believe they are there until noon....at least the one time i went to indio... I can meet you down at the shop on most any Sat....
Brian Hafliger
[Re: Brian Hafliger]
#2681974
07/28/19 10:04 AM
07/28/19 10:04 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
IMM would be my first choice but with my schedule the only way I'd be able to drive out there is if they are open on Saturdays. call and ask...I believe they are there until noon....at least the one time i went to indio... I can meet you down at the shop on most any Sat.... I’ll pretend I didn’t read that..... I prefer a decent excuse to skip a day of work!
#2682033
07/28/19 02:07 PM
07/28/19 02:07 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
IMM would be my first choice but with my schedule the only way I'd be able to drive out there is if they are open on Saturdays. call and ask...I believe they are there until noon....at least the one time i went to indio... I can meet you down at the shop on most any Sat.... Thanks Brian
