Is Driveshaft the same for Belvedere vs Coronet? #2681359
07/25/19 06:23 PM
07/25/19 06:23 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Did some checking online and search engine suck these days.. basically just trying to figure out if a driveshaft from a factory 440 4-speed dana 67 Coronet will fit in a factory 440 4-speed dana Belvedere and vice versa. I know the wheel bases are different so I am thinking no but can't believe Ma Mopar would make two different shafts.
Thanks.
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Mopar_Mike] #2681361
07/25/19 06:33 PM
07/25/19 06:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Belvedere is 51.15", Coronet is 50.27".
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: John_Kunkel] #2681364
07/25/19 06:39 PM
07/25/19 06:39 PM
Danville, NH
Danville, NH
would that make them non compatible?
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Mopar_Mike] #2681369
07/25/19 06:49 PM
07/25/19 06:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I wouldnt swap them.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: gtx6970] #2681370
07/25/19 06:51 PM
07/25/19 06:51 PM
Danville, NH
Danville, NH
I'm reading more online, doesn't look like it will work. Thanks.
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Mopar_Mike] #2681381
07/25/19 07:21 PM
07/25/19 07:21 PM
Since 1963, maybe earlier, Mopar B body have had two different wheel bases, the Plymouth are usually two inches shorter wheel base than the Dodges are scope
The K members and most of the front and rear suspension parts are the same so where do you think the extra two inches occurs between work
As already pointed out, don't do that tsk
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Cab_Burge] #2681395
07/25/19 08:22 PM
07/25/19 08:22 PM
Danville, NH
Danville, NH
Thanks Cab, as always smile
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Mopar_Mike] #2681404
07/25/19 09:06 PM
07/25/19 09:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Being a longer wheelbase, I would have thought the Coronet shaft is longer than the Belvedere.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: topside] #2681405
07/25/19 09:09 PM
07/25/19 09:09 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
X2 the spring hangers are supposed to be shorter in the front on a Plymouth.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: moparpollack] #2681421
07/25/19 09:31 PM
07/25/19 09:31 PM
Danville, NH
Danville, NH
Spring hangers are much shorter on Plymouth’s... 66-7 anyways
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Cab_Burge] #2681501
07/26/19 09:13 AM
07/26/19 09:13 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That is what I have always thought, did John have this backwards?
"Belvedere is 51.15", Coronet is 50.27""
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: 340Cuda] #2681517
07/26/19 10:03 AM
07/26/19 10:03 AM
Danville, NH
Danville, NH
I have both, I’m going to do some measurements this weekend and
will post results.
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: 340Cuda] #2681588
07/26/19 01:01 PM
07/26/19 01:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes he stated it wrong. Dodge is one inch longer than Plymouth for 1966-1967. With same engine trans, rear axle combination.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: NANKET] #2681601
07/26/19 02:17 PM
07/26/19 02:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, my bad. They're listed by R and W body and I get them confused. confused
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: John_Kunkel] #2682169
07/28/19 10:57 PM
07/28/19 10:57 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Since the factory has too much yoke clearance on most cars. I would be tempted to try the longer driveshaft and check for clearance. Most literature will tell you 1.5" of clearance but most of the time that is more than necessary.
If a car sits low and there is very little clearance like 3/4". It will never get closer as the car's suspension compresses, only further.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Magnum] #2682224
07/29/19 07:32 AM
07/29/19 07:32 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I used shaft from a '69 Charger in a '69 road runner, 440 727 8 3/4 to 440 4 speed 8 3/4 with no issues.
1981 Dodge D150 360 auto
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Magnum] #2682244
07/29/19 08:37 AM
07/29/19 08:37 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What do you think happens when the pinion goes from pointing down to pointing up under acceleration?
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Sniper] #2682373
07/29/19 02:18 PM
07/29/19 02:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The rear transmission housing can fail.
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Sniper] #2682468
07/29/19 06:07 PM
07/29/19 06:07 PM
Magnum Offline
Magnum  Offline
If you are pointing down about 4 degrees and the pinion goes to zero. It will kove the yoke forward about 1/8".
Re: Is Driveshaft the same for Belvedere vs Coronet? [Re: Magnum] #2682472
07/29/19 06:19 PM
07/29/19 06:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
How many degrees is it when......
The snubber on the front of pinion bottoms out of the floor reinforcement above it?
