Is Driveshaft the same for Belvedere vs Coronet?
#2681359
07/25/19 06:23 PM
07/25/19 06:23 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Did some checking online and search engine suck these days.. basically just trying to figure out if a driveshaft from a factory 440 4-speed dana 67 Coronet will fit in a factory 440 4-speed dana Belvedere and vice versa. I know the wheel bases are different so I am thinking no but can't believe Ma Mopar would make two different shafts. Thanks.
RS23L7 4-Speed
Re: Is Driveshaft the same for Belvedere vs Coronet?
[Re: Mopar_Mike]
#2681361
07/25/19 06:33 PM
07/25/19 06:33 PM
Posts: 25,994 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Belvedere is 51.15", Coronet is 50.27".
[Re: John_Kunkel]
#2681364
07/25/19 06:39 PM
07/25/19 06:39 PM
Mopar_Mike
Danville, NH
would that make them non compatible?
RS23L7 4-Speed
[Re: Mopar_Mike]
#2681369
07/25/19 06:49 PM
07/25/19 06:49 PM
Posts: 21,505 It's a dry heat
gtx6970
It's a dry heat
would that make them non compatible? I wouldnt swap them.
[Re: gtx6970]
#2681370
07/25/19 06:51 PM
07/25/19 06:51 PM
Mopar_Mike
Danville, NH
I'm reading more online, doesn't look like it will work. Thanks.
RS23L7 4-Speed
[Re: Mopar_Mike]
#2681381
07/25/19 07:21 PM
07/25/19 07:21 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
Since 1963, maybe earlier, Mopar B body have had two different wheel bases, the Plymouth are usually two inches shorter wheel base than the Dodges are ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) The K members and most of the front and rear suspension parts are the same so where do you think the extra two inches occurs between ![work work](/ubbthreads/images/graemlins/custom/work.gif) As already pointed out, don't do that ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
[Re: topside]
#2681405
07/25/19 09:09 PM
07/25/19 09:09 PM
moparpollack
Lil Herman
Lil Herman
85086
Being a longer wheelbase, I would have thought the Coronet shaft is longer than the Belvedere. X2 the spring hangers are supposed to be shorter in the front on a Plymouth.
[Re: moparpollack]
#2681421
07/25/19 09:31 PM
07/25/19 09:31 PM
Mopar_Mike
Danville, NH
Spring hangers are much shorter on Plymouth’s... 66-7 anyways
RS23L7 4-Speed
[Re: Cab_Burge]
#2681501
07/26/19 09:13 AM
07/26/19 09:13 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Since 1963, maybe earlier, Mopar B body have had two different wheel bases, the Plymouth are usually two inches shorter wheel base than the Dodges are ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) The K members and most of the front and rear suspension parts are the same so where do you think the extra two inches occurs between ![work work](/ubbthreads/images/graemlins/custom/work.gif) As already pointed out, don't do that That is what I have always thought, did John have this backwards? "Belvedere is 51.15", Coronet is 50.27""
[Re: 340Cuda]
#2681517
07/26/19 10:03 AM
07/26/19 10:03 AM
Mopar_Mike
Danville, NH
I have both, I’m going to do some measurements this weekend and will post results.
RS23L7 4-Speed
[Re: 340Cuda]
#2681588
07/26/19 01:01 PM
07/26/19 01:01 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
Since 1963, maybe earlier, Mopar B body have had two different wheel bases, the Plymouth are usually two inches shorter wheel base than the Dodges are ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) The K members and most of the front and rear suspension parts are the same so where do you think the extra two inches occurs between ![work work](/ubbthreads/images/graemlins/custom/work.gif) As already pointed out, don't do that That is what I have always thought, did John have this backwards? "Belvedere is 51.15", Coronet is 50.27"" Yes he stated it wrong. Dodge is one inch longer than Plymouth for 1966-1967. With same engine trans, rear axle combination.
[Re: John_Kunkel]
#2682169
07/28/19 10:57 PM
07/28/19 10:57 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Since the factory has too much yoke clearance on most cars. I would be tempted to try the longer driveshaft and check for clearance. Most literature will tell you 1.5" of clearance but most of the time that is more than necessary.
If a car sits low and there is very little clearance like 3/4". It will never get closer as the car's suspension compresses, only further.
[Re: Magnum]
#2682224
07/29/19 07:32 AM
07/29/19 07:32 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
I used shaft from a '69 Charger in a '69 road runner, 440 727 8 3/4 to 440 4 speed 8 3/4 with no issues.
1981 Dodge D150 360 auto
[Re: Magnum]
#2682244
07/29/19 08:37 AM
07/29/19 08:37 AM
Posts: 6,326 nowhere
Sniper
nowhere
If a car sits low and there is very little clearance like 3/4". It will never get closer as the car's suspension compresses, only further. What do you think happens when the pinion goes from pointing down to pointing up under acceleration?
[Re: Sniper]
#2682373
07/29/19 02:18 PM
07/29/19 02:18 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If a car sits low and there is very little clearance like 3/4". It will never get closer as the car's suspension compresses, only further. What do you think happens when the pinion goes from pointing down to pointing up under acceleration? The rear transmission housing can fail.
[Re: Sniper]
#2682468
07/29/19 06:07 PM
07/29/19 06:07 PM
Magnum
If a car sits low and there is very little clearance like 3/4". It will never get closer as the car's suspension compresses, only further. What do you think happens when the pinion goes from pointing down to pointing up under acceleration? If you are pointing down about 4 degrees and the pinion goes to zero. It will kove the yoke forward about 1/8".
