Harmonic Balincer hard to put back on. Whats up? #268114
03/27/09 11:00 AM
03/27/09 11:00 AM
Murrayville, Illinois, usa
scotts66charger Offline OP
I have replaced the stock timing chain, with a new double roller chain and gears, The harmonic balance came off with some prying, but now it seems hard, maybe ever stuck, when I try to put it back on. Do I just need to get a 2x4 and a hammer, and tap it back on, or what do you think I might be up against? Mid 70'S 440 .Thanks. scott
Re: Harmonic Balincer hard to put back on. Whats up? [Re: scotts66charger] #268115
03/27/09 11:02 AM
03/27/09 11:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's a press fit , the wrong way is to hammer it on , the correct way is to draw it on with a balancer installer and or use the bolt .
You PRYED it off ???
Re: Harmonic Balincer hard to put back on. Whats up? [Re: JohnRR] #268116
03/27/09 11:06 AM
03/27/09 11:06 AM
Well, pryed is a bad word. I used a H/B puller. Thanks for the info, I will try that.
Re: Harmonic Balincer hard to put back on. Whats up? [Re: scotts66charger] #268117
03/27/09 11:31 AM
03/27/09 11:31 AM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Factory balancer? Shouldn't be that tough to install, just use a install tool. Aftermarket ones often need to be honed to fit, so don't force it. You can also warm it up in an oven enough to get it on... although not preferred, it shouldn't hurt it as long as you don't get the thing REALLY hot.
Darrah Heath
Re: Harmonic Balincer hard to put back on. Whats up? [Re: VT_Dart] #268118
03/27/09 12:27 PM
03/27/09 12:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's 3/4 fine get a piece of 3/4 fine threaded rod and make your own installation tool. Or get a long 3/4 fine bolt and start pulling it with that and washers till your stock bolt will finish the job
Re: Harmonic Balincer hard to put back on. Whats up? [Re: Dodgem] #268119
03/27/09 04:21 PM
03/27/09 04:21 PM
Right on. Thanx guys !!
Re: Harmonic Balincer hard to put back on. Whats up? [Re: scotts66charger] #268120
03/27/09 10:58 PM
03/27/09 10:58 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Dont' use a bolt to pull it on, you will distort the threads in the crank snout and you will end up hating yourself later. Use threaded rod and a nut with washers.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Harmonic Balincer hard to put back on. Whats up? [Re: Dodgem] #268121
03/28/09 09:27 AM
03/28/09 09:27 AM
CT
3
340KID Offline
340KID  Offline
CT
Is a small block also 3/4 fine ?
