Harmonic Balincer hard to put back on. Whats up?
#268114
03/27/09 11:00 AM
03/27/09 11:00 AM
Posts: 188 Murrayville, Illinois, usa
scotts66charger
I have replaced the stock timing chain, with a new double roller chain and gears, The harmonic balance came off with some prying, but now it seems hard, maybe ever stuck, when I try to put it back on. Do I just need to get a 2x4 and a hammer, and tap it back on, or what do you think I might be up against? Mid 70'S 440 .Thanks. scott
Re: Harmonic Balincer hard to put back on. Whats up?
[Re: scotts66charger]
#268117
03/27/09 11:31 AM
03/27/09 11:31 AM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
Factory balancer? Shouldn't be that tough to install, just use a install tool. Aftermarket ones often need to be honed to fit, so don't force it. You can also warm it up in an oven enough to get it on... although not preferred, it shouldn't hurt it as long as you don't get the thing REALLY hot.
Darrah Heath
#268120
03/27/09 10:58 PM
03/27/09 10:58 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
Dont' use a bolt to pull it on, you will distort the threads in the crank snout and you will end up hating yourself later. Use threaded rod and a nut with washers. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
