Re: Cleaning racing stuff
[Re: moparx]
#2681207
07/25/19 11:11 AM
07/25/19 11:11 AM
Posts: 17,875 S.E. Michigan
ZIPPY
S.E. Michigan
Never never clean anything like that, it's bad luck.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2681229
07/25/19 11:57 AM
07/25/19 11:57 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My recommendation would be to obtain and follow cleaning instructions from the manufacturer. It should all be cleaned occasionally, if for no other reason than to not look and smell like you're homeless and just crawled out from under a bridge - or arrived from San Francisco.
[Re: CMcAllister]
#2681247
07/25/19 12:53 PM
07/25/19 12:53 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
My recommendation would be to obtain and follow cleaning instructions from the manufacturer. It should all be cleaned occasionally, if for no other reason than to not look and smell like you're homeless and just crawled out from under a bridge - or arrived from San Francisco. I agree I will have mine cleaned at the end of our racing season in late Sept. this year, it is a SFI 5 three layer pants and jacket, I get hot in it now and the local track has a lot of dirt in the pits
[Re: Cab_Burge]
#2681258
07/25/19 01:28 PM
07/25/19 01:28 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I throw my single layer fire jacket in the washing machine and then air dry. I haven't worn my multi-layer pants and jacket but a couple of times, so I haven't washed them yet.
[Re: an8sec70cuda]
#2681446
07/25/19 11:37 PM
07/25/19 11:37 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Was not sure if I could this at home and see that I can......https://competitionmotorsport.com/molecule-complete-racing-garment-care-kit?gclid=EAIaIQobChMIuMqj8tLR4wIVhZ-fCh3GrAl5EAQYASABEgLSz_D_BwE
Appears if I dry clean it I would still need the spray on protector....
