Earlier 340 Internals in 1973 318's #2679771
07/21/19 02:55 PM
07/21/19 02:55 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Came across and ad on Craigslist. A guy has a 73 318 long block for sale, claiming that starting in 73 Mopar started putting earlier 340 internals into 318's. ????
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679782
07/21/19 03:15 PM
07/21/19 03:15 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I think he doesn't know his a$$ from his knee cap, but then what do I know?
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679793
07/21/19 03:27 PM
07/21/19 03:27 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Also, weren't the 273, 318 and 340 cranks and rods the same?
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679802
07/21/19 04:09 PM
07/21/19 04:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
As long as it was balanced it should be fine. See if he has proof /receipt of the work .
Re: Earlier 340 Internals in 1973 318's [Re: mopars4ever] #2679807
07/21/19 04:29 PM
07/21/19 04:29 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
It's a used long block. Doesn't look like it's ever had work done to it. He is claiming that ma mopar put 340 internals into 318's, starting in 1973.
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679808
07/21/19 04:29 PM
07/21/19 04:29 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
no
Re: Earlier 340 Internals in 1973 318's [Re: Sniper] #2679810
07/21/19 04:34 PM
07/21/19 04:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Well, some stuff swaps over, bolts, timing covers, brackets, oil pans, etc.
But.........
Do not believe everything you read on the internet or elsewhere.
At times, skepticism is a virtue.
Re: Earlier 340 Internals in 1973 318's [Re: Alaskan_TA] #2679823
07/21/19 06:12 PM
07/21/19 06:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
No mopar didn`t do that. I misread and thought you said he installed 340 internal parts. The 340 went to a cast crank, special balancer around 73 but it was different from the 318. 318`s remained unchanged from what I remember.I would shy away from that deal.
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679840
07/21/19 06:56 PM
07/21/19 06:56 PM
What Mopars4ever said on the receipts/balancing, go check it out skeptically, it may be a good deal (nothing ventured nothing gained). EDIT if parts were swapped I would assume it was balanced).
Re: Earlier 340 Internals in 1973 318's [Re: RapidRobert] #2679843
07/21/19 07:00 PM
07/21/19 07:00 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I had a 72 318 that had those lighter rods like the 273's had, maybe that's what he was trying to say
Re: Earlier 340 Internals in 1973 318's [Re: mopars4ever] #2679849
07/21/19 07:07 PM
07/21/19 07:07 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
rod # 3418645 was used in 73/74 318 same rod 71/73 360 and also 72/73 340 with cast crank .
Non of the 318 & 340 cranks have the same part #'s
Re: Earlier 340 Internals in 1973 318's [Re: GVH] #2679851
07/21/19 07:20 PM
07/21/19 07:20 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The forging part numbers might be the same but the finished part numbers wouldn't be. IIRC 318's and other small blocks had a pressed wrist pin, whereas 340 rods all were bronze bushed and the pistons had floating pins with C Clips.
Re: Earlier 340 Internals in 1973 318's [Re: Sixpak] #2679856
07/21/19 07:46 PM
07/21/19 07:46 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
For crying out loud, he's trying to say the seller is claiming Chrysler built 318's with the same crank and rods as the 340 from the factory. Not that the seller built it that way.
He's not going to have and receipts or paper work showing balancing.
Re: Earlier 340 Internals in 1973 318's [Re: Sniper] #2679858
07/21/19 07:50 PM
07/21/19 07:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Super Cuda why don`t you find another place to annoy people.
Re: Earlier 340 Internals in 1973 318's [Re: Sixpak] #2679893
07/21/19 09:51 PM
07/21/19 09:51 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
source i have says 273 /318 and all 340 up to 73 had floating pins . 318 went to pressed pins in 74 and all 360 had pressed pins .
Re: Earlier 340 Internals in 1973 318's [Re: 500ciDuster] #2679896
07/21/19 10:10 PM
07/21/19 10:10 PM
P
Porter67 Offline
Porter67  Offline
P
Looks like seller corrected his listing.
The power steering pump might be a good grab.
https://portland.craigslist.org/mlt/pts/d/sherwood-mopar-318-la-long-block/6938547508.html
Was...Nearly complete 73’ dated Mopar 318 LA motor with all accessories pictured! Would be a good core motor to rebuild. 1973 is when Mopar started putting the earlier 340 engine internals into their 318 motors. This makes for a great rebuild or stroker! It has a
Now..Nearly complete 73’ dated Mopar 318 LA motor with all accessories pictured! Would be a good core. This makes for a great rebuild or stroker! I have never ran engine so it should be rebuilt before use. Sold as core. Read Less
Re: Earlier 340 Internals in 1973 318's [Re: Porter67] #2679958
07/22/19 01:33 AM
07/22/19 01:33 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Yep, that's the one. Perhaps another of the local Mopar guys called him on it as well.
Re: Earlier 340 Internals in 1973 318's [Re: elmor353] #2679965
07/22/19 02:01 AM
07/22/19 02:01 AM
All the 318 had the same bore from beginning to end, stock is 3.91. correct scope
All 340, 1968 to 1973 had 4.040 bore size, correct? Me thinks that the 340 piston will never fit in a 318, will they work
Another dummy trying to off his junk as something special tsk twocents
Re: Earlier 340 Internals in 1973 318's [Re: Cab_Burge] #2680088
07/22/19 12:59 PM
07/22/19 12:59 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
I bought a 70 318 once for a core with a rod knock for the forged crank, opened it up and it had 4.070 bore TRW forged 340 pistons in it. I still have the block under my shelf as the bores still look great, I just can't convinve myself to put it back together seeing how the normally 165 # block now weighs 122# and the bores sound like glass when I tap on them with my fingernail.
Re: Earlier 340 Internals in 1973 318's [Re: GVH] #2680625
07/23/19 06:11 PM
07/23/19 06:11 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I thought the only motors of that era to get bronzed bushed rods and floating pins were the 340 and the Gen 2 hemi...
