Re: 84 D100 Died, no power
[Re: scannman70]
#2679370
07/20/19 10:37 AM
07/20/19 10:37 AM
RapidRobert
that the lights/radio also died tells you that the ign ain't being fed (starter/cranking circuit is still intact). start at the bulkhead checking for the open & work upstream or downstream from there starting with the blue wire (ign1) circuit. Grab your meter
[Re: RapidRobert]
#2679372
07/20/19 10:39 AM
07/20/19 10:39 AM
Posts: 16,818 Between Houston & Galveston TX
SattyNoCar
Check the harness connector at the column from the ignition switch too. Seen quite a few that were melted.
John
[Re: scannman70]
#2679824
07/21/19 06:16 PM
07/21/19 06:16 PM
Posts: 893 illinois
rbkt65
illinois
1/2 round connector has 7 wires in it. wire 1 is 12 ga dark blue----wire 2 is a double wire 18 ga dark blue w/tracer---- wire 3 is 14 ga pink w/tracer---- wire 4 is 14 ga red----wire 5 is 14 ga light blue----wire 6 is 14 ga orange----wire 7 is 14 ga light blue. wire 1 goes thru bulkhead cavity #4 to fusible link. wire 2,double blue w/tracer, goes to park brake switch and then forward to cavity 14 in bulkhead and goes to 6 way under hood that goes along frame to rear of truck. wire 3, 14 ga pink w/tracer, is cavity 13 in bulkhead and also goes to fuse link. wire 4, 14 ga red,tees off to fuse box and cavity 2 in bulkhead and goes to voltage reg. wire 5,14 ga light blue, tees off to fuse box and wind shield switch. wire 6,14 ga orange,cavity 28 in bulkhead and goes to starter relay. wire 7,14 ga light blue w/tracer goes to fuse box. good luck.
[Re: rbkt65]
#2680236
07/22/19 08:06 PM
07/22/19 08:06 PM
Posts: 879 Pennsylvania
scannman70
Pennsylvania
while checking for power, I discovered that if either door is open, and I touch my tested to the radiator support, hood, fenders etc, It lights up, I have power in the body? If I shut the doors, or just push the door switch in, light goes out and no power...
I checked all 7 pins on half round connector, all have power.
[Re: scannman70]
#2681006
07/24/19 06:33 PM
07/24/19 06:33 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
I forgot my number one rule when doing electric work, Look and see what the last owner did,
Sure enough, Taped up wire going to a fusable link, touched it and wire broke off.
also ground cable from negative on battery to rad support guy had house wire on it and It broke off.
At least I learned a lot about the electronics on my truck..
Thanks to everyone who offered help. So, did that solve the problem?
Abe Lincoln
