Re: Street strip toy!
[Re: BloFish]
#2736320
01/24/20 10:18 PM
01/24/20 10:18 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
No, it is like the one picture on here, short wheel base pick up body It has a lot more room in the drivers department than the Ford Econoline vans or early Chevy vans had, I had to drive both in the late 1960 working for a telephone company in SO CA. Our Engineering Dept. had one Dodge A100 long wheel base passenger van with a lot of windows, but I never rode or drove it. The Econoline vans had 170 C.I. sick six cylinders in them, they had a hard time maintaining 65 MPH down hill wit a tail wind
[Re: @#$%&*!]
#2736502
01/25/20 02:09 PM
01/25/20 02:09 PM
Cab_Burge
Our Engineering Dept. had one Dodge A100 long wheel base passenger van with a lot of windows, but I never rode or drove it. A108 Your correct, thanks for the help
[Re: Keith Richards]
#2736507
01/25/20 02:16 PM
01/25/20 02:16 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Nice Work! They are neat and very light little trucks, tried selling this one for a friend years back, think it still might be in his barn were I left it.
Was that truck in Lodi back in the late 90's? I vaguely remembering seeing it out at Sac raceway and a shop in Lodi around that time.
[Re: Cab_Burge]
#2764594
04/16/20 12:34 PM
04/16/20 12:34 PM
Posts: 19,388 north of coder
moparx
i've thought of that as well cab, but i thought that really applied to very low pressure reading gauges like a fuel pressure unit. i considered this type of coolant temperature gauge as a quick underhood check used with solid mounts. i guess a guy could check the inaccuracy with a temperature gun to see how far off it could be, and use a mental note. [provided i could remember what that "note" was. ]
[Re: moparx]
#2764777
04/16/20 07:57 PM
04/16/20 07:57 PM
Posts: 771 Btween a rock and a hard place
moparlulu
i've thought of that as well cab, but i thought that really applied to very low pressure reading gauges like a fuel pressure unit. i considered this type of coolant temperature gauge as a quick underhood check used with solid mounts. i guess a guy could check the inaccuracy with a temperature gun to see how far off it could be, and use a mental note. [provided i could remember what that "note" was. ] I can only speak to the accuracy of this one. It seems to be spot on with the mechanical auto meter, the last Time I used it....
[Re: moparlulu]
#2778509
05/26/20 08:49 PM
05/26/20 08:49 PM
Posts: 16,477 On the run…
BloFish
On the run…
I feel your pain. Looks awesome!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
