Mopar distributor nylon shaft collar #2678780
07/18/19 05:58 PM
07/18/19 05:58 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
I have a perfectly good MP dist that the nylon shaft collar broke on. Does anyone know where you can get them? If I had not moved my lathe out of state to my retirement home, I would turn one out of alum round stock. Ehrenberg used to sell them but I see none in his E-Bay store.
Re: Mopar distributor nylon shaft collar [Re: Lee446] #2678795
07/18/19 06:35 PM
07/18/19 06:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a mopar bushing kit 2275229. I sent you a PM.
Re: Mopar distributor nylon shaft collar [Re: Lee446] #2678803
07/18/19 06:44 PM
07/18/19 06:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
mopar 2932988
Aftermarket kit
It's just a 1/2" nylon collar, pretty generic
Re: Mopar distributor nylon shaft collar [Re: Lee446] #2678822
07/18/19 07:15 PM
07/18/19 07:15 PM
Yes get a generic collar which will be tighter radially than the OE collar (unless you want it 100% OE). While you are at it reduce the axial clearance to .005" & speedway mtrs has a kit of flat washers for dirt cheap ($4.99 iirc + the ride).
Re: Mopar distributor nylon shaft collar [Re: Lee446] #2679012
07/19/19 10:03 AM
07/19/19 10:03 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Give me the dimensions and tolerance you want and I'll turn one out of aluminum for you. You just pay postage if it's more than a couple bux.
Re: Mopar distributor nylon shaft collar [Re: gzig5] #2679198
07/19/19 07:37 PM
07/19/19 07:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Hillman makes nylon collars that are available at Lowes. I've rebuilt quite a few distributors with them and they work perfect. .99 for two last I checked..
'63 Dodge 330
11.19 @ 121 mph
Re: Mopar distributor nylon shaft collar [Re: GY3] #2679265
07/19/19 11:16 PM
07/19/19 11:16 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Thanks to all who offered help, especially gzig5, what a great offer and I really appreciate it! A friend dug around his parts bin and found one. Thanks much to all!
Re: Mopar distributor nylon shaft collar [Re: GY3] #2679477
07/20/19 03:53 PM
07/20/19 03:53 PM
California
biggE Offline
biggE  Offline
California
Great tip! I just went and bought a few of the two packs at Lowes. The only difference was in CA they are $1.54 per pack plus tax. Typical extra charge for just breathing the air here.
Re: Mopar distributor nylon shaft collar [Re: biggE] #2679480
07/20/19 04:21 PM
07/20/19 04:21 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
They have the roll pins too in a Hillman pack.
Can you post up the part number for the collars? I went looking last night and couldn't find my stash..
'63 Dodge 330
11.19 @ 121 mph
Re: Mopar distributor nylon shaft collar [Re: GY3] #2679669
07/21/19 09:33 AM
07/21/19 09:33 AM
California
biggE Offline
biggE  Offline
California
Can you post up the part number for the collars? I went looking last night and couldn't find my stash.. [/quote]
On the package, It has H# 880447, also UPC# 0823670839 and Lot# HO3967284.
Re: Mopar distributor nylon shaft collar [Re: biggE] #2679717
07/21/19 11:59 AM
07/21/19 11:59 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I wonder how well they do with the engine temps? I assume the quality is there?
Re: Mopar distributor nylon shaft collar [Re: mopars4ever] #2679720
07/21/19 12:04 PM
07/21/19 12:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The last one I used has been in the engine for 5700 hard miles and hundreds of dragstrip passes. It has been over 210 a couple of times but never "overheated".
'63 Dodge 330
11.19 @ 121 mph
Re: Mopar distributor nylon shaft collar [Re: GY3] #2679726
07/21/19 12:11 PM
07/21/19 12:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Good to know. A lot of the Hillman stuff was US made but I noticed a move towards China stuff lately.
