Post deleted by Defbob
[Re: TrWaters]
#267881
03/27/09 07:42 PM
03/27/09 07:42 PM
Re: What Do YOU Want Howards Cams To Make For Mopars?
#267882
03/27/09 08:22 PM
03/27/09 08:22 PM
dartman366
Mt. Vernon, Ohio
lifters as good as Crane Ultra Pro Mechanical Roller Lifters
And with pushrod oiling,,ans also the w2/w5 race rocker, stand and shaft set-up in 1.6 and 1.5 ratio.
#267886
03/27/09 09:41 PM
03/27/09 09:41 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
[Re: Moparteacher]
#267893
03/28/09 05:00 PM
03/28/09 05:00 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Drop-in Hydraulic roller lifters for small block. There are drop-in solid rollers, but as far as I know all the hydraulic rollers available require grinding on the block. thanks, Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: emarine01]
#267894
03/28/09 06:01 PM
03/28/09 06:01 PM
Posts: 251 SD USA
neonic
SD USA
W2/W5 rockers 1.6 1.7 ratio.
sbdemon
