Re: Running hot (still)
[Re: Scott Carl]
#2679065
07/19/19 12:04 PM
07/19/19 12:04 PM
RapidRobert
confirm temp with a good mech gauge. too hot around town or on the highway (or both). timing/mixture in the ballpark? I'd want it a bit closer than 2". multiple blade fan? pulley ratio in the ballpark? I'm assuming no restricted air flow. might need more radiator.
[Re: Scott Carl]
#2679066
07/19/19 12:07 PM
07/19/19 12:07 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Put a shroud and clutch fan on it.
After that, if you still have issues we need more info such as temperature gain idling, temp gain at low speed, temp gain at highway speed, and other such info.
200 degrees is no big deal. not ideal, but not a worry. 230 degrees is a bit worrisome. Anything higher is a serious concern and needs immediate attention..
[Re: RapidRobert]
#2679087
07/19/19 01:10 PM
07/19/19 01:10 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Thanks Robert, Feets. I'm looking for a shroud. Always been in the "plan" lol. I thought about putting a longer spacer in unless I can find the clutch. Thought I had one before I took it apart in '08. Feets, according to gauge (Old sticky SunPro gauge that never bottoms. Starts at about 140, 150. Yeah, I know, get a new gauge ) its running about 220 running constant at 35 and 40. Gets up to 230 in stop and go. My Mopar guru nephew suggested a temp gun and check top to bottom. to determine flow temps. I know its hot as it starts crapping out on acceleration, but smooths out when I'm just cruising. Assuming fuel may be vaporizing in line or bowl?? Scott
[Re: Scott Carl]
#2679129
07/19/19 03:24 PM
07/19/19 03:24 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Thanks Robert, Feets. I'm looking for a shroud. Always been in the "plan" lol. I thought about putting a longer spacer in unless I can find the clutch. Thought I had one before I took it apart in '08. Feets, according to gauge (Old sticky SunPro gauge that never bottoms. Starts at about 140, 150. Yeah, I know, get a new gauge ) its running about 220 running constant at 35 and 40. Gets up to 230 in stop and go. My Mopar guru nephew suggested a temp gun and check top to bottom. to determine flow temps. I know its hot as it starts crapping out on acceleration, but smooths out when I'm just cruising. Assuming fuel may be vaporizing in line or bowl?? Scott If it’s running 220 constant at 35 and 40 mph a shroud and fan clutch will not help You already have plenty of airflow at those speeds
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2679133
07/19/19 03:36 PM
07/19/19 03:36 PM
bee1971
Sobieski Wi
Under the assumption your gauge is accurate
Cooling system is full , no air pockets
First you have to see if you adequate coolant flow thru the radiator at operating temperature
Leave the radiator cap loose , not pressurized , while bringing the car up to operating temperature at idle in park
Remove the cap
Above 180 you should see a nice steady flow of coolant across the top of the radiator
If you don’t - Thermostat not opening , water pump issue , collapsed radiator hose
Second , if you have adequate flow like described above
Radiator , as in it’s plugged or not enough capacity to cool properly
[Re: Scott Carl]
#2679751
07/21/19 01:58 PM
07/21/19 01:58 PM
feets
Senior Management
Senior Management
Irving, TX
Check out the overheating post I bumped up from a few years ago. It'll have the basics to get you going.
