727 real seal #2678503
07/17/19 11:50 PM
07/17/19 11:50 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I am replacing my U-joints and figured I'd do the tail shaft seal while I have the drive shaft out. My question is do I grease/lube the seal or not?
Thank you. wrench
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 727 real seal [Re: 340wedge] #2678519
07/18/19 01:25 AM
07/18/19 01:25 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Wouldn’t hurt ... I’d buff the slip spline with some 400 and then real lightly coat it with some white grease
Re: 727 real seal [Re: dOOc] #2678595
07/18/19 10:43 AM
07/18/19 10:43 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Always lube a new seal! If you are going to use it soon, just a coat of trans fluid on the slip yoke and on the seal surface. If it is going to be a while before use, use some lithium grease like Doc said.
Re: 727 real seal [Re: 340wedge] #2678698
07/18/19 02:13 PM
07/18/19 02:13 PM
340wedge Offline OP
340wedge  Offline OP
White lithium grease it is, thank you both! beer...We need a thank you button and like button like forabodiesonly!
