727 real seal #2678503
07/17/19 11:50 PM
07/17/19 11:50 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I am replacing my U-joints and figured I'd do the tail shaft seal while I have the drive shaft out. My question is do I grease/lube the seal or not?
Thank you. wrench
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 727 real seal [Re: 340wedge] #2678519
07/18/19 01:25 AM
07/18/19 01:25 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Wouldn’t hurt ... I’d buff the slip spline with some 400 and then real lightly coat it with some white grease
Re: 727 real seal [Re: dOc !] #2678595
07/18/19 10:43 AM
07/18/19 10:43 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Always lube a new seal! If you are going to use it soon, just a coat of trans fluid on the slip yoke and on the seal surface. If it is going to be a while before use, use some lithium grease like Doc said.
Re: 727 real seal [Re: 340wedge] #2678698
07/18/19 02:13 PM
07/18/19 02:13 PM
340wedge Offline OP
340wedge  Offline OP
White lithium grease it is, thank you both! beer...We need a thank you button and like button like forabodiesonly!
