Intake air temps
#2678669
07/18/19 01:04 PM
07/18/19 01:04 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have asked on many forums at what IAT does performance fall off without any real replies. With my combo it starts falling off at 170*.Threw more fuel & boost at it with no performace gain.140 MPH was like a wall that day at atco. Been looking at W/M for intercooling but I'm now thinking nitrous for the race mode. I wouldn't doubt that a 50 shot could give me over 100 HP due to the lower IAT. What do you think??
Re: Intake air temps
[Re: 451Mopar]
#2678683
07/18/19 01:29 PM
07/18/19 01:29 PM
fast68plymouth
So. Burlington, Vt.
What’s the IAT on something like a Hellcat with a pulley and a tune?
[Re: A/MP]
#2678770
07/18/19 05:32 PM
07/18/19 05:32 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
What are running as fuel? VP 16 will help you make the power and avoid any detonation. Q16 will make it even better as long as you fatten it up enough and can stand the smell
[Re: fast68plymouth]
#2679057
07/19/19 11:44 AM
07/19/19 11:44 AM
hemi-itis
What’s the IAT on something like a Hellcat with a pulley and a tune? That is a great question,they use an a/c evap to intercool. I am leaning towards the NO2........ Cab,if the meth has all the cooling properties required,why do they even use water??
[Re: hemi-itis]
#2679079
07/19/19 12:35 PM
07/19/19 12:35 PM
Cab_Burge
What’s the IAT on something like a Hellcat with a pulley and a tune? That is a great question,they use an a/c evap to intercool. I am leaning towards the NO2........ Cab,if the meth has all the cooling properties required,why do they even use water?? I have no idea, you know the deal about some guys can't drink straight whiskey without water in it, correct Maybe it is the same deal on their cars AKA aside adding water to the mix has never made sense to me I stated thinking about putting room temperature water on your skin versus putting alcohol on your skin and which one cool down the quickest Same thing in the motor, correct : up:
[Re: hemi-itis]
#2679081
07/19/19 12:39 PM
07/19/19 12:39 PM
Posts: 1,178 Indy
FlyFish
Indy
What’s the IAT on something like a Hellcat with a pulley and a tune? That is a great question,they use an a/c evap to intercool. I am leaning towards the N2O........ Cab,if the meth has all the cooling properties required,why do they even use water?? Fixed it for ya...carry on.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#2679092
07/19/19 01:18 PM
07/19/19 01:18 PM
hemi-itis
What’s the IAT on something like a Hellcat with a pulley and a tune? That is a great question,they use an a/c evap to intercool. I am leaning towards the N2O........ Cab,if the meth has all the cooling properties required,why do they even use water?? Fixed it for ya...carry on. OOOPS
[Re: hemi-itis]
#2679173
07/19/19 05:39 PM
07/19/19 05:39 PM
fast68plymouth
So. Burlington, Vt.
The Hellcat doesn’t have the extra IAT cooling provided by the A/C unit like the Demon does...... but it does untilize s a pair of intercoolers. Doing a little digging....... The goal is to reduce the temperature of the intake air to less than 140 degrees Fahrenheit so the water and antifreeze mixture is maintained at about 100 degrees F.
#2679177
07/19/19 05:51 PM
07/19/19 05:51 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
The Hellcat doesn’t have the extra IAT cooling provided by the A/C unit like the Demon does...... but it does untilize s a pair of intercoolers. Doing a little digging....... The goal is to reduce the temperature of the intake air to less than 140 degrees Fahrenheit so the water and antifreeze mixture is maintained at about 100 degrees F. Supposedly they can run flat out for 20 minutes before the ECU dials things back due to heat. Probably pretty close to out of gas at that point also lol
68 Barracuda Formula S 340
#2679225
07/19/19 08:47 PM
07/19/19 08:47 PM
Superfreak
Superfreak
Take the roots off and go with a Whipple twin screw.
[Re: ]
#2679263
07/19/19 11:11 PM
07/19/19 11:11 PM
hemi-itis
Take the roots off and go with a Whipple twin screw. Out of my budget but a nice upgrade
[Re: A/MP]
#2679694
07/21/19 10:59 AM
07/21/19 10:59 AM
hemi-itis
What are running as fuel? VP 16 will help you make the power and avoid any detonation. That would be more octane that I need.I have not gone over an effective CR of 15: and will stay there untill I get it very happy.I'm getting very close with the carbs and sill experimenting with timing.Last 2 times out the top end charge is not there When the cooler air comes in the fall I will check plugs after every run instead of just reading the racepak. I will also try different heat ranges. I have the start and cruise lookin good,now need to work on WOT. Question........will the plugs read the same at the top of 2nd just into high gear as they will at the stripe? I go over the stripe at 64/6500 rpm
