Intake air temps #2678669
07/18/19 01:04 PM
07/18/19 01:04 PM
Great Neck,LI,new york
hemi-itis Offline OP
I have asked on many forums at what IAT does performance fall off without any real replies. With my combo it starts falling off at 170*.Threw more fuel & boost at it with no performace gain.140 MPH was like a wall that day at atco.
Been looking at W/M for intercooling but I'm now thinking nitrous for the race mode. I wouldn't doubt that a 50 shot could give me over 100 HP due to the lower IAT. What do you think??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Intake air temps [Re: hemi-itis] #2678676
07/18/19 01:16 PM
07/18/19 01:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would go with straight methanol injection to start with and tune it as needed up Water doesn't burn and alcohol evaporates and absorbs heat a lot faster than water and it burns also scope
Re: Intake air temps [Re: hemi-itis] #2678677
07/18/19 01:18 PM
07/18/19 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Should help.. just fog it into the front.. should cool everything
wave
Re: Intake air temps [Re: hemi-itis] #2678680
07/18/19 01:23 PM
07/18/19 01:23 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Too high IAT can lead to pre-ignition, not sure what the point is as it will change with cylinder pressure.
Re: Intake air temps [Re: 451Mopar] #2678683
07/18/19 01:29 PM
07/18/19 01:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What’s the IAT on something like a Hellcat with a pulley and a tune?
Re: Intake air temps [Re: fast68plymouth] #2678696
07/18/19 02:12 PM
07/18/19 02:12 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
What are running as fuel? VP 16 will help you make the power and avoid any detonation.
Re: Intake air temps [Re: A/MP] #2678770
07/18/19 05:32 PM
07/18/19 05:32 PM
Q16 will make it even better as long as you fatten it up enough and can stand the smell scope up twocents
Re: Intake air temps [Re: fast68plymouth] #2679057
07/19/19 11:44 AM
07/19/19 11:44 AM
That is a great question,they use an a/c evap to intercool. I am leaning towards the NO2........
Cab,if the meth has all the cooling properties required,why do they even use water??
Re: Intake air temps [Re: hemi-itis] #2679079
07/19/19 12:35 PM
07/19/19 12:35 PM
I have no idea, you know the deal about some guys can't drink straight whiskey without water in it, correct devil whistling Maybe it is the same deal on their cars whistling grin
AKA aside adding water to the mix has never made sense to me shruggy
I stated thinking about putting room temperature water on your skin versus putting alcohol on your skin and which one cool down the quickest work scope Same thing in the motor, correct : up:
Re: Intake air temps [Re: hemi-itis] #2679081
07/19/19 12:39 PM
07/19/19 12:39 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
That is a great question,they use an a/c evap to intercool. I am leaning towards the N2O........
Fixed it for ya...carry on. grin
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Intake air temps [Re: FlyFish] #2679092
07/19/19 01:18 PM
07/19/19 01:18 PM
blush OOOPS up laugh2
Re: Intake air temps [Re: hemi-itis] #2679173
07/19/19 05:39 PM
07/19/19 05:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Hellcat doesn’t have the extra IAT cooling provided by the A/C unit like the Demon does...... but it does untilize s a pair of intercoolers.
Doing a little digging.......
Quote
The goal is to reduce the temperature of the intake air to less than 140 degrees Fahrenheit so the water and antifreeze mixture is maintained at about 100 degrees F.
Re: Intake air temps [Re: fast68plymouth] #2679177
07/19/19 05:51 PM
07/19/19 05:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Quote
Supposedly they can run flat out for 20 minutes before the ECU dials things back due to heat. Probably pretty close to out of gas at that point also lol
68 Barracuda Formula S 340
Re: Intake air temps [Re: Cab_Burge] #2679205
07/19/19 07:54 PM
07/19/19 07:54 PM
Me thinks that N2O will cool better and have a little more "kick" work
Re: Intake air temps [Re: hemi-itis] #2679207
07/19/19 07:56 PM
07/19/19 07:56 PM
So. Burlington, Vt.
So. Burlington, Vt.
Sounds like you’re going to find out.
Re: Intake air temps [Re: fast68plymouth] #2679225
07/19/19 08:47 PM
07/19/19 08:47 PM
Superfreak
Superfreak
Take the roots off and go with a Whipple twin screw.
Re: Intake air temps [Re: ] #2679263
07/19/19 11:11 PM
07/19/19 11:11 PM
Out of my budget but a nice upgrade whistling
Re: Intake air temps [Re: fast68plymouth] #2679264
07/19/19 11:12 PM
07/19/19 11:12 PM
Path of least $$$$ At the present.Just need a few weeks of "busy"!!!
Re: Intake air temps [Re: A/MP] #2679694
07/21/19 10:59 AM
07/21/19 10:59 AM
That would be more octane that I need.I have not gone over an effective CR of 15: and will stay there untill I get it very happy.I'm getting very close with the carbs and sill experimenting with timing.Last 2 times out the top end charge is not there shruggy When the cooler air comes in the fall I will check plugs after every run instead of just reading the racepak. I will also try different heat ranges.
I have the start and cruise lookin good,now need to work on WOT.
Question........will the plugs read the same at the top of 2nd just into high gear as they will at the stripe? I go over the stripe at 64/6500 rpm work
Re: Intake air temps [Re: hemi-itis] #2679754
07/21/19 02:08 PM
07/21/19 02:08 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The load is not the same in 2nd as in 3rd at 6500 to check plugs.did you take off the air filters?This may help at top end and the tune you are looking for.
