Re: I really want the Thermoquad sound but should I?
[Re: LAD 524]
#2679633
07/21/19 06:14 AM
07/21/19 06:14 AM
Posts: 1,756 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I wanna try out this combo for fun once I get my new hood. Ive prepped up a pair of #6322 TQs with some tweaks, freshened them up and put in new throttle shaft bushing. VERY interested to see how they will dial in on the X ram ... LAD 5241: Did you replace the shaft bushings yourself, or sent it out? If yourself, can you provide the pertinent part # info and any procedure details? Thanks!
[Re: feets]
#2679641
07/21/19 07:29 AM
07/21/19 07:29 AM
Diplomat360
Windsor, ON, Canada
I believe the TQ can be tuned to just about any combination. However, having said that, the more radical you get in the cam selection the harder of a time you are going to have in trying to get the card to respond to the engine vacum signal changes. My base for this statement: I've been using these things for years and currently run the aftermarket 9800 series (the one with the attached electric choke on the side). It took some work to get the idle mixture screws to actually respond, so literally the engine runs differently as you turn the screws. Previously in my combo (238/244 @0.050 duration hydraulic flat tappet cam) only the idle speed screw did anything. That cam is pulling only about 6-7" of vacum though. Dave Emanuel's book is a great reference if you are new to these carbs and are going to work on them (ISBN 0-931472-11-3). I have a nice Carter tech book on this carb, but it's too big to attach, so IM me and we can exchange through email.
[Re: stumpy]
#2681642
07/26/19 05:14 PM
07/26/19 05:14 PM
Posts: 6,235 nowhere
Sniper
nowhere
Nice except for the $1800 price with pump and extras. And it probably don't have that TQ howl
[Re: Sniper]
#2681654
07/26/19 06:12 PM
07/26/19 06:12 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Nice except for the $1800 price with pump and extras. And it probably don't have that TQ howl That's an interesting question. I has always assumed it was a function of the LARGE secondaries. So I wouldn't be surprised if this produced a similar effect...Q-Jets had some of that. But nothing barks quite like a TQ.
[Re: BlueGhost]
#2681675
07/26/19 08:02 PM
07/26/19 08:02 PM
Posts: 12,039 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Even IF that Sniper EFI delivered any real benefit over a Street Demon, there is no way it can possibly deliver 6 times the benefits over the Street Demon which is how much more it costs. Plus the extra labor.
I have said this before, The only guys that dismiss the Street Demon for our mostly stock and mostly street cars, are guys that haven't tried one.
Master, again and still
[Re: DaveRS23]
#2681678
07/26/19 08:35 PM
07/26/19 08:35 PM
Sniper
nowhere
I have said this before, The only guys that dismiss the Street Demon for our mostly stock and mostly street cars, are guys that haven't tried one. Or wants the TQ sound.
[Re: Sniper]
#2681765
07/27/19 09:58 AM
07/27/19 09:58 AM
RWG75
RWG75
I have said this before, The only guys that dismiss the Street Demon for our mostly stock and mostly street cars, are guys that haven't tried one. Or wants the TQ sound. One of the things that I dig most about my old stuff is that they're not efi, computer controlled, technology dependant. Sure, there are times when I gotta pop the hood to get one started but I'll take that over wrestling with a smart phone app any day. As for something that sounds like a TQ, I'm thinking the thing that comes closest is a TQ.
[Re: Diplomat360]
#2681973
07/28/19 10:01 AM
07/28/19 10:01 AM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
[quote LAD 5241: Did you replace the shaft bushings yourself, or sent it out? If yourself, can you provide the pertinent part # info and any procedure details? Thanks! [/quote] Yep bought a kit with the ream and the bushes. Disassemble the carb, and you can use the ream in reverse in the drill chuck and the straight shaft on the ream is used as a guide in the throttle bores to enable you to ream it straight and true. Then loctite the new bushes and drive them in - I used a bolt with the correct OD and the threads cut off to use it as a bush driver. Worked like a charm https://www.youtube.com/watch?v=UvHIWqdJX8shttps://www.ebay.com/itm/3-8-Throttle-Shaft-Bushing-repair-Worn-Carburetor-contain-Reamer-16-pcs-Bushing/232906517346?hash=item363a4f6b62:g:JXQAAOSwFSNcAdk3
