Upgrade A518 46RH for SRT8 #2677476
07/15/19 04:10 AM
07/15/19 04:10 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
I want to do an upgrade for my A518 46RH trans that will go behind my 2014 6.4 hemi SRT8. The engine produces 470 HP and 485 ft pound of torque.
Which parts do I need to do the upgrade?
Re: Upgrade A518 46RH for SRT8 [Re: dickdale] #2677487
07/15/19 07:05 AM
07/15/19 07:05 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
didn't know that trans would even bolt up to that engine.
Re: Upgrade A518 46RH for SRT8 [Re: dickdale] #2677543
07/15/19 09:55 AM
07/15/19 09:55 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Talk to CRT, John Cope, he is a vendor here.
Re: Upgrade A518 46RH for SRT8 [Re: dickdale] #2677925
07/16/19 12:55 PM
07/16/19 12:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Upgrade A518 46RH for SRT8 [Re: John_Kunkel] #2678690
07/18/19 01:49 PM
07/18/19 01:49 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I would do a search on this and other Mopar sites concerning CRT/John Cope before I spent any money there... Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Upgrade A518 46RH for SRT8 [Re: BANDIT] #2679518
07/20/19 07:10 PM
07/20/19 07:10 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
A good shift kit and extra clutches! That should last along time! I'll give you an update in 8mo when mine is done!
Re: Upgrade A518 46RH for SRT8 [Re: dickdale] #2693810
09/02/19 11:32 PM
09/02/19 11:32 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
That is so easy it’s not funny. A good valve body, high pressure, about 200 psi. A good converter and upgrade all the drums to hold more clutches! Including OD direct and brake.
Re: Upgrade A518 46RH for SRT8 [Re: mcmopar1] #2694023
09/03/19 05:00 PM
09/03/19 05:00 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
use the guts out of a V10 or cummins tranny----on the RH you only need to change the governor weight....
Re: Upgrade A518 46RH for SRT8 [Re: dickdale] #2694463
09/04/19 07:37 PM
09/04/19 07:37 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
if its a 2wd application, I would do a nag1 with at stand alone controller.
Re: Upgrade A518 46RH for SRT8 [Re: Uberpube] #2694502
09/04/19 10:12 PM
09/04/19 10:12 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
why do the nag1 instead of the a518
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Upgrade A518 46RH for SRT8 [Re: Jerry] #2694511
09/04/19 10:55 PM
09/04/19 10:55 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Jerry,
When is your website going to be done? Still selling the serpentine belt kits for BB and Hemi Mopars?
Re: Upgrade A518 46RH for SRT8 [Re: Jerry] #2694734
09/05/19 05:00 PM
09/05/19 05:00 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The more speeds the merrier, ride in something with an auto shift with a lot of gears where you can keep on the power peak of the motor, its like adding 150hp.
Re: Upgrade A518 46RH for SRT8 [Re: Uberpube] #2712887
11/05/19 04:44 AM
11/05/19 04:44 AM
Right here
HP2 Offline
HP2  Offline
Right here
I was thinking the same. I'm still gathering parts for my build. Have a 6.1 and a 46RH for the 71 Duster but have started to hesitate.
Wouldn't a modern tranny with more gears be better?
Then it comes to size. To fit the 46RH in I need to do some cutting and fabbing a new support. Then I could cut a little more and make room for something better with more gears.
Or is there a slimmer multi gear tranny out there? Best shift-bang for the bucks? What options do we have?
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Upgrade A518 46RH for SRT8 [Re: HP2] #2712999
11/05/19 01:34 PM
11/05/19 01:34 PM
IL
furious70 Offline
furious70  Offline
IL
yes you'll be doing fab work either way. Less people have done the nag1 so more pioneering there. Then the cost of the Sound German controller for the nag1 and the learning curve. I plan to do it someday and have a nag1 now for fab work.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Upgrade A518 46RH for SRT8 [Re: furious70] #2713341
11/06/19 01:09 PM
11/06/19 01:09 PM
GA
roadrunninMark Offline
GA
The Nag1 weighs less, about 160 lbs w/ convertor vs about 200 lbs w/ convertor for the 46RH. It might take less hp to turn it too. Talk to Russel at Sound German Automotive, he is an expert on the Nag1, has all kids of goodies for them too, besides the controller.
Re: Upgrade A518 46RH for SRT8 [Re: furious70] #2716294
11/16/19 07:16 AM
11/16/19 07:16 AM
Right here
HP2 Offline
HP2  Offline
Right here
I have sent a bunch of questions to Sound German. I have only good experience from ZF transmissions so it will be interesting to hear what they have to say about NAG1 compared to 8HP70.
71 Duster 340
