hemi intake heat shield #2677348
07/14/19 03:58 PM
07/14/19 03:58 PM
central il.
second 70 Offline OP
central il.
I'm getting ready to install the heat shield on my manifold and wanted to know if you loctite the bolts or use anti seize on them? This is a stage V manifold and using factory shield and bolts with captive washers.
Thanks Mike
Re: hemi intake heat shield [Re: second 70] #2677372
07/14/19 06:13 PM
07/14/19 06:13 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I always use lock-tite.
Re: hemi intake heat shield [Re: second 70] #2677442
07/14/19 10:39 PM
07/14/19 10:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
On any motor that has the possibility to have any bolts come out while the motor is running you should take every effort possible to make they don't come out until you want them out twocents work
Re: hemi intake heat shield [Re: second 70] #2677492
07/15/19 07:26 AM
07/15/19 07:26 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I used red loctite on mine ...
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: hemi intake heat shield [Re: rumblefish72] #2677574
07/15/19 11:33 AM
07/15/19 11:33 AM
central il.
central il.
Thanks for the confirmation. Red loctite is what I used in the past I just thought I'd ask to verify.
Re: hemi intake heat shield [Re: second 70] #2677654
07/15/19 01:44 PM
07/15/19 01:44 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Red loctite is only removable once cured by heating up parts to 500°F, It's only the valley tray not a high heat or vibration bolt, I think Loctite Threadlocker Blue 242 is more suited for the task.
