Re: Hemi rear main seal replacement
[Re: second 70]
#2678039
07/16/19 06:55 PM
07/16/19 06:55 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Probably already checked but most of the aftermarket oil pan bolts are a touch longer than factory and will bottom out and not compress the gasket. Found this out my hemi. I thought it was rear main also. My easy solution was to add 1 grade 8 flat washer to each bolt. My block has studs for the oil pan, so my pans tightened right up against the block. Thanks for the heads up though.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: 73cuda340]
#2678123
07/16/19 11:05 PM
07/16/19 11:05 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
Probably already checked but most of the aftermarket oil pan bolts are a touch longer than factory and will bottom out and not compress the gasket. Found this out my hemi. I thought it was rear main also. My easy solution was to add 1 grade 8 flat washer to each bolt. My block has studs for the oil pan, so my pans tightened right up against the block. Thanks for the heads up though. Does your motor have main studs also? If so look at the rear of the oil pan and the oil pan gasket under the rear main seal and see if the #5 main studs are touching them ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) If so you may have found your oil leak before removing the rear main seal holder again ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: Cab_Burge]
#2678552
07/18/19 08:18 AM
07/18/19 08:18 AM
73cuda340
clarks summit pa
Probably already checked but most of the aftermarket oil pan bolts are a touch longer than factory and will bottom out and not compress the gasket. Found this out my hemi. I thought it was rear main also. My easy solution was to add 1 grade 8 flat washer to each bolt. My block has studs for the oil pan, so my pans tightened right up against the block. Thanks for the heads up though. Does your motor have main studs also? If so look at the rear of the oil pan and the oil pan gasket under the rear main seal and see if the #5 main studs are touching them ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) If so yonu may have found your oil leak before removing the rear main seal holder again Yes, the motor does have main studs. Do you mean check to see if the studs are hitting the oil pan itself or the rear main seal retainer?
[Re: sthemi]
#2678558
07/18/19 08:34 AM
07/18/19 08:34 AM
73cuda340
clarks summit pa
My son just built a 383, we combined the rope seal kit with the blue side seal kit and so far, really good.
does your crank have the knurling in the seal area to accommodate the rope seal? The crank doesn't have any knurling.
[Re: 73cuda340]
#2678563
07/18/19 08:57 AM
07/18/19 08:57 AM
Posts: 668 IL
Dart451
IL
[Re: Cab_Burge]
#2681023
07/24/19 08:17 PM
07/24/19 08:17 PM
73cuda340
clarks summit pa
I've got the motor torn back apart again. There are no contact marks on the oil pan. There are very slight signs of contact from the nuts on the main cap touching the windage tray. The replacement oil pan gaskets that I installed are slightly thicker, so there isn't anymore interference. The problem that I'm having now is trying to get the upper half of the rear main seal out from the block. I think it's from the rtv on the back of it holding it in. Are there any tips on getting this out without it breaking or ruining anything with the block or crank. I'm afraid of it tearing and still being stuck in there and then I'll be screwed.
[Re: 73cuda340]
#2681142
07/25/19 08:59 AM
07/25/19 08:59 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
You will need to push the top of the seal out with self made tool (heat and bend a thin cheap screwdriver, cut or grind the head off it and polish it up) or similar while turning the crankshaft at the same time in the same direction you're pushing it.
One you get the top part of the seal out, how will you clean all that nasty rtv out of the seal groove, though?
For many years I've read the advice here to use rtv and other products on the back side of the dynamic seal (dynamic meaning the part the crankshaft rotates against), I feel it is not needed and disagree.
RTV as a substitute for the side seals is okay. The old white asbestos side seals have always worked fine for me but I usually injected rtv after they were installed. And since they stopped making them, it's been straight rtv after that.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2682078
07/28/19 05:26 PM
07/28/19 05:26 PM
Posts: 2,431 USA
SSAAHemiFan
USA
[Re: 68_661charger]
#2682144
07/28/19 09:19 PM
07/28/19 09:19 PM
Posts: 3,114 Michigan
A727Tflite
I always get raked over the coals for suggesting to loosen the rear main to get the upper seal out but if you do this the seal comes right out with no turning of the crank. With an auto trans - remove the converter bolts and push the converter back to disengage it from the crank. Then loosen up the main caps - more at the rear and less at the front of the engine. That may make things easier for you. What I would do then is remove each cap one at a time and make sure the bearing shell tang is in place then install that cap and tighten. Since you are turning the crank you don’t want to take a change that a shell rotated out of alignment.
[Re: A727Tflite]
#2682424
07/29/19 04:30 PM
07/29/19 04:30 PM
73cuda340
clarks summit pa
The car is a 4 speed. I'm going to try a windshield seal install tool first before loosening anything first. The problem is the rtv that's holding it in. When I took the original seal out, I was able to pull it out easily without loosening anything or even turning the crank. This is what worries me that something is machined wrong and the motor will always leak.
[Re: 73cuda340]
#2684789
08/05/19 08:59 PM
08/05/19 08:59 PM
73cuda340
clarks summit pa
[s][/s]
Well, I got everything back together on the motor and I ended up installing the seal at the 12 and 6 o'clock positions. I started the car up and let it idle for probably about 15 minutes without a drop of oil coming out. However, as soon as I sat in the car and gave it some gas, it started leaking like a sieve again. Let off of the gas, and it will continue to idle without leaking. I just don't get it. I at least have it where it will idle at operating temperatures without leaking, but still has a terrible leak under even slight throttle. It's looking like another summer with no driving time at all at this point.
[Re: 73cuda340]
#2684824
08/05/19 11:27 PM
08/05/19 11:27 PM
Cab_Burge
Which way is the upper sealing edge of the seal pointing, towards the front or rear of the engine?
[Re: Cab_Burge]
#2684893
08/06/19 09:29 AM
08/06/19 09:29 AM
73cuda340
clarks summit pa
Which way is the upper sealing edge of the seal pointing, towards the front or rear of the engine? Towards the front.
[Re: Cab_Burge]
#2685089
08/06/19 06:58 PM
08/06/19 06:58 PM
73cuda340
clarks summit pa
Are there any ideas as to what would cause the leak only to happen while the motor is being reved? If the seal was damaged and or installed incorrectly, shouldn't it leak at all times? Is it possible that it's a crankcase pressure issue that is building up pressure during higher rpm's?
