Cooling System Air Lock?
#2677299
07/14/19 11:20 AM
07/14/19 11:20 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think I am having problems with cooling system air lock on that 505 trick flow headed engine now? Owner has a the universal flex type radiator hoses, and the upper seems too long and I think air might be getting trapped in it? Car seemed to be overheating, so we changed thermostat, and replaced the "chrome" housing which was leaking under pressure with a stock thermostat housing. Pressurized the cooling system, and it is holding pressure, so I don't think we have any leaks. Using a IR Temp gun, the pump housing is around 190-200, but the radiator is way cooler, making me think the coolant is not circulating. Had stock iron water pump housing, and stock replacement / rebuilt water pump. Found two issues before I left yesterday. #1 - The aftermarket gauges were reading high because they were connected to a bad ground. Suspected a bad ground when the voltage gauge was reading about 11 volts and when measuring at the battery, it was about 13.8 volts. Added a ground wire from the battery to where the gauges were grounded, and not voltage reads correct, oil an temps are reading lower, So I think part of the "overheating" may have been false reading from the gauges? #2 - Burped air out of the upper radiator hose. Seems air was being trapped in the hose.
Took the car for a short drive, and temps did climb to 190-200? with a 160 degree thermostat. Really did not have (or fuel) for a longer drive.
Will have to see if temps stabilize, but I think replacing the upper radiator hose may help. Not sure if a better water pump would help also?
Re: Cooling System Air Lock?
[Re: 451Mopar]
#2677309
07/14/19 11:58 AM
07/14/19 11:58 AM
RapidRobert
#1 (as you know) find accurate temps with a good mech gauge.Then is it running too hot around town or on the highway (or both). Holler back when you can.
[Re: 451Mopar]
#2677454
07/14/19 11:28 PM
07/14/19 11:28 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
https://www.autozone.com/shop-and-g...ension-and-e-adapter-for-ford/255743_0_0Colorado in July... I imagine it’s pretty toasty. You’d have to have the cooling system from h377 to keep that 160 thermo happy. I’d put a 180 if not 190 in. You “hope” that with heat exchange the tstat will close some and allow for heat transfer of the coolant in the radiator. ....and EVERYONE should have that funnel! It’s awesome!
[Re: jlatessa]
#2680056
07/22/19 11:23 AM
07/22/19 11:23 AM
451Mopar
Aurora, Colorado
I raise the front of the car about a foot on the initial fill and warm-up, seems to help getting the heads clear of air pockets. Did you try that?
Joe That is a great idea! The owner replaced the stock water pump with a 440 Source pump, refilled the cooling system with the front end in the air, and re-routed the trans cooler lines too, and now says it is running cool.
[Re: 451Mopar]
#2680073
07/22/19 11:59 AM
07/22/19 11:59 AM
Posts: 287 PA
Harry's Taxi 2
PA
I know it's a little late for your engine now, but I've been putting a bleeder valve in the back of each head for quite some time now and that really speeds up radiator filling.
I've seen spring loaded push to release valves and they a little nicer looking, but I just use 1/8" radiator petcocks.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: moparx]
#2680576
07/23/19 04:48 PM
07/23/19 04:48 PM
Posts: 287 PA
Harry's Taxi 2
PA
..... I've been putting a bleeder valve in the back of each head for quite some time now and that really speeds up radiator filling...... I just use 1/8" radiator petcocks. would you, by chance, have a pic or two of this ? I don't have any on my computer at the moment, but i'll take a couple tomorrow.
[Re: MoonshineMattK]
#2680659
07/23/19 07:54 PM
07/23/19 07:54 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Get yourself a vacuum radiator fill kit. You wont regret it How do these work? I just googled the kit. It looks enticing
[Re: moparx]
#2680884
07/24/19 11:51 AM
07/24/19 11:51 AM
Posts: 287 PA
Harry's Taxi 2
PA
I try to put them as high in the water jacket as possible.
I'd like to bleed all four corners, but of course the stock distributer gets in the way. don't know if an msd might give a little more room since they're higher.
the one picture is of a future project indy-1 head and the other is the current engine indy-ez head.
