Re: Patch a slick tube?
[Re: dvw]
#2677012
07/13/19 10:08 AM
07/13/19 10:08 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Doug, I don't know if its the correct repair but I have patched them and they held. fwiw. Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#2677015
07/13/19 10:22 AM
07/13/19 10:22 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I quit using tubes 30 years ago but yes it can be done. Been there done that.
[Re: JAKE68]
#2677038
07/13/19 11:50 AM
07/13/19 11:50 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Doug, I don't know if its the correct repair but I have patched them and they held. fwiw. Jake Me too, several times ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
[Re: nss guy]
#2677144
07/13/19 06:28 PM
07/13/19 06:28 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
And I just threw away 4 good 10x30 tubes... I would have sent them all to you for spares. Sorry about the bad luck. They can be patched.
[Re: nss guy]
#2677147
07/13/19 06:35 PM
07/13/19 06:35 PM
RapidRobert
we would scuff the surface around the puncture. Clean that surface with some "cleaner". Install the patch. roll a "tool" back & forth & sideways over the patch (not sure how to describe the tool) but it had "cleates". remove what is left of the "cover" from the patch. add air & dunk it & see if no bubbles.
[Re: hemi-itis]
#2677171
07/13/19 08:30 PM
07/13/19 08:30 PM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm old enough to have patched tires, and tubes, plenty of them. I would patch a race tube, if it was a small hole. Heck, I've plugged tubeless slicks.
[Re: nss guy]
#2677214
07/13/19 11:06 PM
07/13/19 11:06 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Big difference if you're at home or at the track going rounds Yep. No tubes = plug it and keep going.
[Re: Leigh]
#2677256
07/14/19 08:30 AM
07/14/19 08:30 AM
Posts: 9,883 MI, usa
dvw
MI, usa
Big difference if you're at home or at the track going rounds This. Trust me this has crossed my mind. Trying to be consistent in the low 9's bracket or 9.25 index on a 10.5 tire is tough. Since going to tubes there have been no more out of nowhere +.05 60fts. Which in the past have cost me. Doug
[Re: Leigh]
#2677258
07/14/19 08:33 AM
07/14/19 08:33 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Big difference if you're at home or at the track going rounds This. Luckily in my case it only had to hold 13.5 psi for a few seconds..... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
