Idle /Off Idle Problem PT Cruiser
#2671917
06/30/19 12:40 PM
06/30/19 12:40 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
06 PT 82,000 miles. Started as in park or neutral hot,it would chug/surge /miss then stall. Drop it in gear,smooth..no issues. Morphed into does it in gear also and lite throttle under 2 ,000rpm. Does this about 30% of the time. Ran codes ..no codes. But check engine light on. Replaced, TPS....nope Idle Motor. ...nope Intake Temp sensor ...nope. Plugs...nope.
Ideas, ,theories? ????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Idle /Off Idle Problem PT Cruiser
[Re: 71birdJ68]
#2671937
06/30/19 01:31 PM
06/30/19 01:31 PM
6bblFLASH
N.E. Ohio
Where did you buy the sensors that you changed? Mopars don't like cheap auto parts store sensors. OEM off our other PT
[Re: AARCONV]
#2677007
07/13/19 09:52 AM
07/13/19 09:52 AM
6bblFLASH
N.E. Ohio
Fixed. Broken O2 wire. Intake gasket leak.
