Re: Feedback on BB Victor heads using T&D rockers?
[Re: BradH]
#2676318
07/10/19 03:37 PM
07/10/19 03:37 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I have the T&D Victor rockers on my 440 Source heads. I know, not much help.
[Re: CSK]
#2676399
07/10/19 08:51 PM
07/10/19 08:51 PM
BradH
No problem. How have they worked out?
Found a pic someone else posted years ago of the MW version (.725 intake offset vs .650). .
[Re: BradH]
#2676682
07/11/19 11:21 PM
07/11/19 11:21 PM
CSK
Pattison Texas
so far 3000 miles & all is good.
[Re: fbs63]
#2676784
07/12/19 11:41 AM
07/12/19 11:41 AM
CSK
Pattison Texas
T&D single shaft rockers are limited to 1.550 diameter valve spring. I know guys clearance them or use other means of fitting them. Spend the money on the individual shaft versions. You won't regret it. UNLESS YOU USE B3's geometry correction locators that move the rockers up & back from the valves.
[Re: CSK]
#2676804
07/12/19 12:45 PM
07/12/19 12:45 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I forgot to mention on the standard shaft setup, T&D uses a slightly smaller diameter shaft that is really thick walled. The #2, #3, and #4 stud hold downs are machined smaller where they align with the rocker shafts oil hole. A solid stud may cut off oil in the rocker shaft. As mentioned, if going high lift, stiff springs, the paired shaft setup is likely a stronger and more stable setup. http://tdmach.com/product/big-block-mopar-edelbrock-440-victor-max-wedge-58-shaft-paired-system/
