Re: Pro comp rockers
[Re: 72sat]
#2676698
07/12/19 12:37 AM
07/12/19 12:37 AM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
They are sleeved....with coated copper I believe. They work great! Haven't had any issues with them or the valve covers off all season so far. I did size a lot of the spacers to fit though during the build process. I have a lathe so it was no big deal.
[Re: 72sat]
#2676741
07/12/19 08:39 AM
07/12/19 08:39 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Why not just run the aluminum body directly on the steel shaft?
1. Anywhere whatsoever basically totals the rocker, unless you have the facilities to board the hole oversized (without altering its location), and then put a bushing in. for something made with a replaceable bushing, you press the old one out, press the new one in, ream or hone to size. Your component is now far more easily kept serviceable, with just an arbor press and a drill press.
2. Aluminum is not a really great bearing material against Steel. If there is ever a problem with it running dry, it's fairly prone to galling. Brass and bronze have much better inherent lubricity, and are more forgiving of occasional insufficient lube.
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: Dragula]
#2676748
07/12/19 09:43 AM
07/12/19 09:43 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Because they are not aluminum... Good one captain obvious Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
