Aluminum Cylinder Head Clearance
#2676539
07/11/19 11:21 AM
07/11/19 11:21 AM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
While trying to install the Holley distributor to enable timing control on my Sniper setup I discovered the base of the distributor hits the head and won't seat properly. I've marked the area that needs to be clearanced. What do you guys think, rotary file? I could probably get a grinding disc in there, but the aluminum would load up on the disk.
Re: Aluminum Cylinder Head Clearance
[Re: AndyF]
#2676677
07/11/19 10:56 PM
07/11/19 10:56 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've got a inline cutoff wheel that would work great for that, I'd use it like a grinder and let the wheel make a nice cut using in a sweeping motion. It would make a nice concave cut in the head, I would then clean it up with a inline belt sander. The concave shape would fit the distributor.
Have a great day Iowan
"obsolete is neat"
[Re: MarkZ]
#2676701
07/12/19 01:08 AM
07/12/19 01:08 AM
Posts: 31,077 Oregon
AndyF
[Re: Sniper]
#2676739
07/12/19 08:28 AM
07/12/19 08:28 AM
MarkZ
Worthy
Worthy
So what does this distributor bring to the show that a lean burn distributor doesn't? Other than clearance issues and triple the price, or more? It uses hall effect sensors as opposed to magnetic pickup for the trigger. I guess mag pickups don't provide a clean enough signal for the ECU. I'll report back when I've had a chance to work on the car. Thanks everyone.
[Re: krautrock]
#2676900
07/12/19 07:43 PM
07/12/19 07:43 PM
AndyF
Andy, what heads did you use on that motor? Trickflow? No, that engine had Mopar Performance 452 aluminum heads. My new engine has Trick Flow heads and they did not require clearancing.
[Re: AndyF]
#2679486
07/20/19 04:44 PM
07/20/19 04:44 PM
MarkZ
Worthy
Worthy
I feel rather silly now, but yeah, I did and I didn't even remember that bit. Going to Menard's in the morning to pick up a sanding drum.
[Re: MarkZ]
#2679799
07/21/19 03:53 PM
07/21/19 03:53 PM
MarkZ
Worthy
Worthy
Distributor fits. Went with Andy's advice and picked up a sanding drum with a 50 grit roll. Turns out the cap to CRC contact cleaner is exactly the right diameter to use a template for a distributor hole cover. Was also able to put a shopvac downwind of the chips - still made a mess, but not as bad as it could have been. Thanks again everyone.
