Vibration #2676208
07/10/19 11:15 AM
07/10/19 11:15 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
2007 dodge truck hemi 4 wheel drive - - when I get to 62 MPH feel vibration and it goes away at 75. Also if i leave off gas when it is vibrating it goes away . . Don't really feel it in steering wheel . .
any ides ? ?
Re: Vibration [Re: ct440rod] #2676358
07/10/19 06:25 PM
07/10/19 06:25 PM
Guitar Jones Offline
1500, 2500, or 3500? How many miles? Any work done to it lately?
Re: Vibration [Re: Guitar Jones] #2676363
07/10/19 06:37 PM
07/10/19 06:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the pinion nut and the u joints. Also check the trans mount. If you feel it in your seat it's probably a drive train issue. Or maybe a rear tire.
Re: Vibration [Re: stumpy] #2676491
07/11/19 07:59 AM
07/11/19 07:59 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
1500 with 93,386 miles . . I did put new front wheel bearing on about 6 months ago but this vibration just started . . .
Re: Vibration [Re: ct440rod] #2676679
07/11/19 11:05 PM
07/11/19 11:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I agree with Stumpy, I'd be looking at the u joints, the trans mount and the rear pinion nut being loose. All these would give you a vibration like you have, that wouldn't be felt in the steering wheel. Gene
