Vibration #2676208
07/10/19 11:15 AM
07/10/19 11:15 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
2007 dodge truck hemi 4 wheel drive - - when I get to 62 MPH feel vibration and it goes away at 75. Also if i leave off gas when it is vibrating it goes away . . Don't really feel it in steering wheel . .
any ides ? ?
Re: Vibration [Re: ct440rod] #2676358
07/10/19 06:25 PM
07/10/19 06:25 PM
Guitar Jones Offline
1500, 2500, or 3500? How many miles? Any work done to it lately?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Vibration [Re: Guitar Jones] #2676363
07/10/19 06:37 PM
07/10/19 06:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the pinion nut and the u joints. Also check the trans mount. If you feel it in your seat it's probably a drive train issue. Or maybe a rear tire.
Re: Vibration [Re: stumpy] #2676491
07/11/19 07:59 AM
07/11/19 07:59 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
1500 with 93,386 miles . . I did put new front wheel bearing on about 6 months ago but this vibration just started . . .
Re: Vibration [Re: ct440rod] #2676679
07/11/19 11:05 PM
07/11/19 11:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I agree with Stumpy, I'd be looking at the u joints, the trans mount and the rear pinion nut being loose. All these would give you a vibration like you have, that wouldn't be felt in the steering wheel. Gene
