Re: Got lucky with the Hemi
[Re: Dragula]
#2676386
07/10/19 08:14 PM
07/10/19 08:14 PM
fast68plymouth
So. Burlington, Vt.
Spring was weak....... hammered the retainer for a while....... before they finally broke.
That coulda been ugly.
“If it were me”....... it would get all new springs, retainers, locks.
[Re: BradH]
#2676394
07/10/19 08:35 PM
07/10/19 08:35 PM
fast68plymouth
So. Burlington, Vt.
Well, the outer spring appears to be broken........ so I don’t know if the failure would be damper related.
I think Chips Cuda is a good example of moderation with regards to spring loads and cam lobes when it comes to rollers and street driving...... and being able to get decent service life and still running good ET’s.
[Re: Dragula]
#2676500
07/11/19 08:43 AM
07/11/19 08:43 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
WOW ! Close one for sure ! How did you happen to look ? Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: gsmopar]
#2676535
07/11/19 10:52 AM
07/11/19 10:52 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You've had a lot of bad luck with this engine. I hope things are turning around for you! It’s not just this engine. He could write a do not do book 📖
[Re: pittsburghracer]
#2676572
07/11/19 02:06 PM
07/11/19 02:06 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
You've had a lot of bad luck with this engine. I hope things are turning around for you! It’s not just this engine. He could write a do not do book 📖 Basically true.....lol Hopefully I can fix this with the head on the engine. I really don't want to pull the head, I guess I will see.
[Re: Dragula]
#2676578
07/11/19 02:19 PM
07/11/19 02:19 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
WOW!!! You definitely need to go buy some lottery tickets! I couldn't be happier w/ the cam Dwayne spec'd for mine. It must be a bad week for hemis. Mine has an issue, but I think I caught it early before any real damage has been done. I'll know more when I get time to get it apart.
