Got lucky with the Hemi #2676378
07/10/19 07:34 PM
07/10/19 07:34 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
That was a close one...,
Re: Got lucky with the Hemi [Re: Dragula] #2676386
07/10/19 08:14 PM
07/10/19 08:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Spring was weak....... hammered the retainer for a while....... before they finally broke.
That coulda been ugly.
“If it were me”....... it would get all new springs, retainers, locks.
Re: Got lucky with the Hemi [Re: Dragula] #2676388
07/10/19 08:28 PM
07/10/19 08:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Valve springs with flat coil dampers between dual springs? Those dampers chew up ti retainers, unfortunately. If you like the springs, switch to steel retainers; if you want ti retainers, switch to dual springs without dampers.
Re: Got lucky with the Hemi [Re: BradH] #2676390
07/10/19 08:33 PM
07/10/19 08:33 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Buy a lottery ticket, man !
That's the poster child for "it coulda been a lot worse"...
Re: Got lucky with the Hemi [Re: BradH] #2676394
07/10/19 08:35 PM
07/10/19 08:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well, the outer spring appears to be broken........ so I don’t know if the failure would be damper related.
I think Chips Cuda is a good example of moderation with regards to spring loads and cam lobes when it comes to rollers and street driving...... and being able to get decent service life and still running good ET’s.
Re: Got lucky with the Hemi [Re: Dragula] #2676397
07/10/19 08:39 PM
07/10/19 08:39 PM
I'm really glad you found that before it hurt you, the motor or the car up
Re: Got lucky with the Hemi [Re: Cab_Burge] #2676423
07/10/19 10:09 PM
07/10/19 10:09 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Whew........that could have been really ugly.
Re: Got lucky with the Hemi [Re: tubtar] #2676437
07/10/19 11:05 PM
07/10/19 11:05 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
OMG!!!
Re: Got lucky with the Hemi [Re: sixpackgut] #2676455
07/10/19 11:49 PM
07/10/19 11:49 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
You've had a lot of bad luck with this engine. I hope things are turning around for you!
Re: Got lucky with the Hemi [Re: gsmopar] #2676474
07/11/19 05:54 AM
07/11/19 05:54 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
Like the old saying,'Id rather be lucky than good'!
Couple weeks ago I backed mine out of the garage and broke a rockerarm idling. They are old factory SS pieces. I even found the lash cap in the rear drain hole.
Re: Got lucky with the Hemi [Re: quickd100] #2676475
07/11/19 06:36 AM
07/11/19 06:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Better in the driveway than at WOT!! eek I recently found 4 lifters going south and a broken inner spring.Call it luck................... shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Got lucky with the Hemi [Re: Dragula] #2676500
07/11/19 08:43 AM
07/11/19 08:43 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
eek WOW ! Close one for sure ! How did you happen to look ?
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Got lucky with the Hemi [Re: Hemi Allstate] #2676510
07/11/19 08:59 AM
07/11/19 08:59 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
What springs and what retainers - is that a lash cap in there? biggest killer of the roller springs on the street is the lack of cooling by oil - its a tough compromise - glad you found it early that would have been real ugly!
Re: Got lucky with the Hemi [Re: gsmopar] #2676535
07/11/19 10:52 AM
07/11/19 10:52 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
It’s not just this engine. He could write a do not do book 📖
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Got lucky with the Hemi [Re: tubtar] #2676537
07/11/19 11:15 AM
07/11/19 11:15 AM
BradH Offline
BradH  Offline
Yep, regardless of the root cause of the problem, the end result avoided could have been puke
Re: Got lucky with the Hemi [Re: Dragula] #2676538
07/11/19 11:18 AM
07/11/19 11:18 AM
central il.
second 70 Offline
second 70  Offline
central il.
That's scary.
Re: Got lucky with the Hemi [Re: second 70] #2676565
07/11/19 01:10 PM
07/11/19 01:10 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
eek
72 Plymouth Roadrunner 11.08@123.25
Re: Got lucky with the Hemi [Re: pittsburghracer] #2676572
07/11/19 02:06 PM
07/11/19 02:06 PM
Dragula Offline OP
Dragula  Offline OP
Basically true.....lol
Hopefully I can fix this with the head on the engine. I really don't want to pull the head, I guess I will see.
Re: Got lucky with the Hemi [Re: Dragula] #2676578
07/11/19 02:19 PM
07/11/19 02:19 PM
an8sec70cuda Offline
WOW!!! You definitely need to go buy some lottery tickets!
I couldn't be happier w/ the cam Dwayne spec'd for mine.
It must be a bad week for hemis. Mine has an issue, but I think I caught it early before any real damage has been done. I'll know more when I get time to get it apart. frown
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Got lucky with the Hemi [Re: an8sec70cuda] #2676599
07/11/19 03:41 PM
07/11/19 03:41 PM
central il.
second 70 Offline
second 70  Offline
central il.
Sorry to hear that Chip I hope the problem is minor.
