Bleeding Dakota brakes #2675566
07/08/19 01:56 PM
07/08/19 01:56 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
I have to replace the front brake lines on my 04 Dakota due to them being heavily rusted. The rears look fine. What I would like to know is, upon replacing the front lines, will I need to bleed the entire system on all four corners or just the fronts?
Re: Bleeding Dakota brakes [Re: 6PAX] #2675610
07/08/19 04:10 PM
07/08/19 04:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Should be able to get away with just the fronts. Don't leave the system open any longer than necessary.
Re: Bleeding Dakota brakes [Re: stumpy] #2676438
07/10/19 11:10 PM
07/10/19 11:10 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Fill the m/c leaving the cap off crack the frt bleeders till fluid drips out tighten bleeders. 3/4 press of the m/c and crack them again. should take ten minutes.
